SVS and loud fan noise
HondaRacer
Matt
Delaware
23 MME GT
This happened immediately upon starting the car and shortly after level 2 charging at home in my garage. Quite a loud fan noise like someone holding a playing card inside a box fan. Definitely abnormal like nothing I’ve heard before. I’m used to the more quiet hums and noises the car makes. It was accompanied by Service Vehicle Soon on the display. I turned the car off, back on, and all is normal. This is a new ‘23 GT I’ve had for a month.
Should I be concerned? Now I’m just waiting for it to happen again and I don’t want to get stuck somewhere.
Shayne
Northern Ontario Canada
2021 MME4x Prem
When the car over heated in the beginning the cooling fan took off and sounded as you describe. Sounded like it was hurting but Ford replied here and note it causes no damage. Is something blocking the cars front vents or they are not working? Guess if it is normal now drive it.
The SVS should have thrown a DTC. If you don’t have a code reader, there are members here who can retrieve them if you give them your VIN.
HondaRacer
HondaRacer
Matt
Delaware
23 MME GT
There were some leaves that had blown into the garage. Not many, but perhaps one blocked a fan inlet underneath? Nothing at all by the front inlets.
HondaRacer
HondaRacer
Matt
Delaware
23 MME GT
If someone can do that via private message, I’d be happy to send my VIN. Thanks.
Kmp14
Ken
Chicago
2023 Mach-E Premium AWD Extended
I frequently hear something like that when I remote start while the vehicle is plugged in. Walk out to the garage, hear the sound, ignore it, disconnect the charging cable, happily drive away. :) I am usually the type that worries about every sound, but I am focused on NOT doing that with my MME. I think the sound is normal.
HondaRacer
HondaRacer
Matt
Delaware
23 MME GT
Good to know. But I’d be less concerned if I hadn’t seen SVS and a yellow wrench symbol.
Kmp14
Ken
Chicago
Yeah, sorry, I didn't realize that SVS means "Service Vehicle Soon" even though you clearly said it in your post. Reading is a skill, duh on me.
Shayne
2021 MME4x Prem
One leave should not do it there are two sets of vents and are spaced. I know It does not like its vents blocked. There is a European YouTube video of it during his L2 charging (2021?) he lived in row housing and neighbors were not happy at all. Maybe search it to see if that is the sound.
HondaRacer
HondaRacer
Matt
Delaware
23 MME GT
This might be it. Sounds similar if it also had that thwacking “playing card in a fan sound.” May indeed have been a leaf. But I’ve never heard the fan this loud. I don’t think that would be normal for level 2 charging in a 50 degree garage?
Shayne
2021 MME4x Prem
Appears there are a few videos around. The one I mentioned was pretty comical. It wasn't normal and was fixed. That is the fan noise working hard (too hard for L2). Guess you didn't know you had a jet engine in there? ;) Maybe check the vents make sure they are not blocked and are working. And the codes will help. Good to know it's working now.
SOBDMC P0AEE Drive Motor Inverter Temperature Sensor 'A' Circuit Range/Performance
So that would appear to be a failed temperature sensor inside the rear motor inverter causing the failsafe cooling to activate. This will require a dealer visit.
HondaRacer
HondaRacer
Matt
Delaware
23 MME GT
Ok thank you and everyone. This forum is amazing.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Mach-E
Hi there, I'd be happy to look into your Mach-E concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
