Taillight tint
Murse-In-Airy
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Instead of going darker en went for the blood look :cool:
Personally I never really liked the white on white look of the taillights and full dark on white didn't do it for me either. Dark red taillights on white cars I always fancied so I ordered a strip of "dark" translucent (90%) red wrap for $ 15 and gave it a try myself.
Although it was my first "wrapping" experience i'm very pleased with the result.
The center brakelight will be done soon too but I ran out of wrapping material.
Does look better. I agree. White taillights just seem wrong.
derelict
Socal
2021 Mach E Premium AWD ER
Do you guys have any tips on how to get good adhesion without bubbles? These lights have a lot of sharp features which seems much more difficult that what I have seen watching the installation videos online...
Murse-In-Airy
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
I cut the film to approximate size then start with it bent over my squeegee. Using that as a tucking tool to ensure the first adhesion point is the underside of the sharp angle of the taillights. Then it’s just a matter of wrapping it up over the top. Pretty easy when done one light at a time.
derelict
Socal
Thanks! I'll give it a shot...
Murse-In-Airy
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Nah. I just like to accessorize. A bad influence wouldn’t tell you when my ideas went poorly, which I also always share for everyone’s education. Enjoy your tinting.
JBA
The Netherlands
MME RWD SR
I did it with a waterspry with a 1 drop of soap in it. Spray the taillight and glue side of the wrap and put it on. You can move it very easilly in place and once you have a part of the warp inplace press all water below it away with a creditcard and work your way up or down. The sharp bends I heated with a hairdryer and pressed it with the creditcard to stretch and fix it in place.
First one failed, 2nd one succeeded but took a while but after that i got the hang of it and put them on quite easilly. All depends on a good precut though.
note: Best to put soft cloth around the creditcard to make it less sharp.
AButtonMasher
Detroit, MI
Ford Mustang Mach E GT Performance Edition
Designer
Dammit. I think I started this the opposite way and FML. Getting it to wrap the underside is going to put me in the loony bin.
Ford Mustang Mach-E Taillight tint D1F94819-CEE7-405C-84AE-568B6D4483AE
time to start over!
Murse-In-Airy
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
time to start over!
Cut it to smaller pieces first. Do one light at a time.
Murse-In-Airy
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Oh crap! You didn’t wrap the entire housing? Just the actual lit sections? Yeah, should make life easier.
Yeah. Sorry if that wasn’t obvious. Each bar of the tribar was done individually. Makes it very easy to do.
fallguy
fallguy
The south
2020 Defender, 1968 Mustang, 2021 Mach-E GT
Federal
Ordered mine, we'll see how it goes. I don't have the best patience, why I stopped painting... But reading the entire thread gives me a bit of hope.
derelict
Socal
I had the same problem... started trying to wrap the whole light (like the videos all show) and it is nearly impossible if you are not a professional due to all the sharp nooks and crannies these lights have. Then I realized that murse and others who have done this just did the individual lights. After a palmface moment, I tried it and it is soooo much easier!
fallguy
fallguy
The south
Federal
Do you happen to have a link to a good video showing installation?
AButtonMasher
Detroit, MI
Designer
Ford Mustang Mach-E Taillight tint 2B82337F-053A-46F4-90CC-1D529D926A09
Finally got both done. Second light went much better. I’ll try and take a better pick after I get this thing clean. I ordered just light smoke without the hex. Debating doing headlights. But at the rate car projects go with late nights after little one goes to bed it could be a little while. Looks sick with Dark Matter Gray. Thanks for the tips and pointers along the way.
