Sandpiper
- Jul 17, 2024
- Toronto Canada
- Mach e 2024 AWD Extended Range
Some of these issues have already been rectified such as the battery preconditioning. Only the 2nd issue is really perplexing but I guess it was out of warranty?There were a couple issues
1st was the software change that Ford made to compensate for the faulty charge port issue. Instead of fixing the charge ports, they changed the software to throttle the Level 2 charge speed to keep the charge port from overheating.
And nobody even knew it had happened. Seems like this should have been in the software release notes at a minimum.
One day my car was charging nice and fast at 9.6 kwh's and the next day it was down to 6KW
I took it to the dealership and they were as useless as Bruce Jenner's breast milk
They kept the car for over a week, charged it up one time using a 6kwh charger and said they could find nothing wrong. Even though I had told them it only seems to happen when using a 10KWH charger. Again, the dealership was useless
The service advisor told me he had multiple MME's in the shop for the same reason, so that should have been their first clue. But they could not be bothered to even try and work through the problem. It was not until I saw a post on this forum that I found out what the cause was.
2nd was the known issue with the coax cable for the front camera. Mine failed, and again this is a known defect. The dealership quoted a price of over $3k to replace (they wanted to replace the coax cable, the camera, and the IPMA) and again, because the dealership is useless, they could not say that it would fix the problem. I would just have to cough up $3k and see if they could fix it.
3rd is just the terribly slow recharge speed at DCFC's
and
4th is related to 3rd, there were many times in the winter of 2022 when EA was starting to fall apart, I would plug in and only get a 32KW recharge speed and I thought it was the car limiting the charge rate because the battery was cold, because back then they did not even have the precondition by navigating to a charger feature in the software) but I had no way of knowing because the car did not and still does not display anything about the charge rate, i.e. requested speed from charger and speed the charger is delivering. ( in 2021 the EA chargers themselves displayed this info, but they removed it from the screens)
It was not until much later that I realized that the 32KW speed was the default speed for an EA charger when it has a problem that does not completely take it offline, had the car displayed the requested charge rate I could have known it was the charger and tried switching to a different charger. So in the winter of 2022 I spent a lot of time unnecessarily at charge stations recharging at 32KW's because of this aversion of Ford to giving the drivers info about what the car is doing.
5th is related to 4th, the fact that there is so much info that Ford does not display, information that would be important to know. i.e. is the car preconditioning the battery or not. Who knows? the car doesn't say if it is
There are other smaller issues, but these were the biggest for me.
