BadgerGreg
- Greg
- Dec 2, 2020
- North Carolina
- 2023 Mach E Premium RWD SR and 2022 BMW i4 M50
- Engineer
I was out and about last night, and while running errands I noticed that my right front tire had lost a few pounds of pressure (it was down to 34 psi...nothing major, but 6 psi less than the other tires). Instead of seeking out a gas station to get air, I just broke out my tire repair kit, plugged it into my 12V outlet in the center console, and inflated the tire on the spot. The inflator hose has a threaded end that screws onto the valve stem and makes it easy to inflate without having to hold it in place. Since the pump isn't very fast, this is a nice feature (adding 6 pounds of pressure took about 30 seconds or so). The pressure gauge on the repair kit was accurate (tested it against my own hand-held gauge). Took only a couple of minutes and I was on my way.
Just make sure you have the selector switch set to "inflate" and not "repair".
I was definitely happy to have another reason to avoid a gas station.
