precisionair
- Woody
- Dec 29, 2025
- Grandview Tx
- 2023 Lightning ER Pro & 2025 MME Rally
- HVAC Contractor
These are their heaviest lift (capacity) @ 8000 lbs max. Going to be removing the factory sways and installing the Steeda Bars. Plenty of room to work under vehicle.
Thanks for your posting. I have the QJ 8000 also and a 2025 Mache. Do you use lifting pucks or just use the QJ lifting blocks?These are their heaviest lift (capacity) @ 8000 lbs max. Going to be removing the factory sways and installing the Steeda Bars. Plenty of room to work under vehicle.
Wound up using the lifting blocks that came with it; one tall & one short stacked on each corner…Thanks for your posting. I have the QJ 8000 also and a 2025 Mache. Do you use lifting pucks or just use the QJ lifting blocks?
Sounds kind of like my buddy’s garage. He can’t get his Blazer through the opening without taking off the roof and taking some air out of the tires.Can’t realistically fit them in our garage. Our garage is detached and is the ground floor of a 2 story building. Thus, it has reasonably low ceilings with a garage door opener above each parking spot. At best i’d have to convert to a wall mounted door opener.
Well not quite that bad. Our Raptor fits in one of the bays. Just. We’d still need to dump the ceiling mount garage door opener though. I’m not sure how much safe lift we’d get on the Raptor.Sounds kind of like my buddy’s garage. He can’t get his Blazer through the opening without taking off the roof and taking some air out of the tires.![]()
