Trying out the QuickJack system
Can’t realistically fit them in our garage. Our garage is detached and is the ground floor of a 2 story building. Thus, it has reasonably low ceilings with a garage door opener above each parking spot. At best i’d have to convert to a wall mounted door opener.
boomslang
Rustin
Missouri
2025 Mach E GT
I use the Quick Jack 8000TLX. They work awesome for my Mach E and my Lightning.
Flyboy
Eric
New Orleans
2021 Job-2 Mach E Premium, AWD Ext Battery
Retired Industrial Hygienist, Consultant - ISO 17025 Lab Auditor
I have the 5000# rated Quick Jack and have used it many times on my '21 AWD EXT Battery. The distance between the front and rear jack points is pretty tight, but it can be done, and it has plenty of lift capability.
phidauex
Colorado
Renewable Energy Engineer
Nice! The QuickJack isn't the cheapest, but it is a great quality of life improvement for someone with enough space to use them, but not enough space for a permanent lift. The ability to go up a full 24" doesn't sound like a big difference compared to jack stands at first, but for me it is the difference between having to squat down to pull a wheel off vs being able to pull it off from a mostly-standing position.
For others shopping, looking for refurbished models from Bendpak is a good way to save a little money, and many models seem to work with the MachE. I have a 6000TL, because that was the weight and dimensions that best fit all three of my current vehicles. Works great for the MachE.
cdub
2025 Ford Mach e
These are their heaviest lift (capacity) @ 8000 lbs max. Going to be removing the factory sways and installing the Steeda Bars. Plenty of room to work under vehicle.
Thanks for your posting. I have the QJ 8000 also and a 2025 Mache. Do you use lifting pucks or just use the QJ lifting blocks?
precisionair
precisionair
Woody
Grandview Tx
2023 Lightning ER Pro & 2025 MME Rally
HVAC Contractor
Wound up using the lifting blocks that came with it; one tall & one short stacked on each corner…
Sounds kind of like my buddy’s garage. He can’t get his Blazer through the opening without taking off the roof and taking some air out of the tires. 😰🐩
Well not quite that bad. Our Raptor fits in one of the bays. Just. We’d still need to dump the ceiling mount garage door opener though. I’m not sure how much safe lift we’d get on the Raptor.
