- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Another update to the HVBJB replacement TSB. Two notable changes. One is the HVBJB part numbers in the TSB have been updated to match the current 23S56 recall. Second is that late 2022 and 2023 model year vehicles have been dropped from this TSB. It now only applies to vehicles built before May 28 2022. I'm not sure why this change was made, but my guess it is has to do with HVBJB part allocation to align with the recall.
TECHNICAL SERVICE BULLETIN Illuminated MIL And/Or Powertrain Malfunction (Wrench) Indicator With Various DTCs - Built On Or Before 28-May-2022 | 24-2017 25 January 2024 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This bulletin supersedes 23-2348. Reason for update: revise the model years affected, production clean date and part list Model:
Issue: Some 2021-2022 Mustang Mach-E vehicles built on or before 28-May-2022 may exhibit an illuminated malfunction indicator lamp (MIL) and/or powertrain malfunction (wrench) indicator with diagnostic trouble codes (DTCs) P0563, P0ADA, P0ADE, P0AA1, P0AA4, P0AA5, P0AA2, P0D10, P0D0F and/or P0C78 stored in the battery energy control module (BECM). It may also have a low/discharged 12V battery and/or display a Stop Safely Now message in the instrument panel cluster (IPC). This may be due to the high voltage battery junction box (HVBJB). To correct the condition, follow the Service Procedure to replace the HVBJB and reprogram the BECM. Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
Parts
Parts - Parts To Inspect And Replace Only If Necessary
Unit of Issue refers to the number of individual pieces included in a service part number package. Piece Quantity refers to the total number of individual pieces required to repair the vehicle. As Needed indicates the amount of the part may vary and/or is not a whole number. Parts can be billed out as non-whole numbers, including less than 1. If Needed indicates the part is not mandatory. Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions Warranty/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions Warranty/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. Labor Times
Service Procedure 1. Replace the HVBJB. Refer to Workshop Manual (WSM), Section 414-03A, Removal and installation. 2. Reprogram the BECM to latest software available. The BECM is part of the powertrain coordinated flash. (1). Connect a battery charger to the 12-volt battery. If the 12-volt battery is discharged, charge the battery. Refer to WSM, Section 414-01, Diagnosis and Testing. NOTE: To prevent the battery saver mode from activating on the vehicle, make sure the negative cable of the charger is installed on a chassis or engine ground, and not the 12-volt battery negative terminal. Do not have the vehicle plugged into the high voltage battery charger during programming. This can cause incorrect module programming. Make sure only the 12-volt battery charger is installed. 3. Reprogram the PCM using the latest software level of the Ford Diagnosis and Repair System (FDRS) scan tool. 4. Check the availability of software updates on the following modules and update as required:
6. If DTCs P0ADA, P0ADE, P0AA1, and/or P0AA4 remain present, download and run the BECM - Reset Diagnostic Trouble Code (DTC) Occurrence Counter application in FDRS. |
