Motomax
- Max
- Jul 19, 2021
- California
- VW GLI, 4Runner
As far as I know, There’s no difference between brake-hold and 1PD applying the brakes.Brake-hold requires some throttle to disengage the brakes. If you're not ready for that throttle to be translated into motion when the brake releases, it will lunge forward. Brake-hold really isn't necessary if you're using 1PD, so I would turn it off.
I can release the brake-hold without the vehicle moving beyond a forward creep. Either something is wrong or you need a finer touch on the accelerator.
OP are you sure you’re not activating the pre collision braking? I’ve had it apply when backing down a steep driveway and it takes quite a bit of throttle to override it.
