phidauex
- Sam
- Dec 8, 2020
- Colorado
- 2021 MachE 4EX, 2006 Prius, 1997 Tacoma
- Renewable Energy Engineer
I beg you to please ignore any press release that doesn't include a working prototype with independent testing. I work in this industry and one of our mottos is "liars, damned liars, and battery suppliers". They know that they can continue to get investment as long as they say good sounding things, right up until they can't hide the truth anymore, then pull their golden ripcord and float off to the next project.
As for batteries themselves, lithium is a very mature technology, and has been improving steadily every year - the batteries we have now would have been miraculous 10 years ago, so give them some credit.
In order to improve charging speeds, two things need to go up - the battery voltage, and the chemistry stability. Stationary energy storage systems (grid scale) are up to 1500VDC now, and we are knocking on the door of 2kV. A charging cable will always be limited by the resistance of copper, and even with cooling a 2000A cable will barely be practical - you might be able to put some kind of gantry on it to support the cable weight during charging, but it isn't the "fuel pump handle analog" you are thinking of. At 1600V, you could run 4X the power for the same thermal losses as our MachEs, or 2X the 800V systems.
Chemistry stability is the real devil though, because longevity and charge rate are inversely proportional. In order to get 20 year lifespans out of the best current technology we limit the charge rate to 0.25C, which would be equivalent to a 4 hour charge time. EVs give up some longevity in order to get faster charge times, but you can only push it so far. There are drone batteries that can handle 50C charges and discharges, but they may only last a handful of cycles at that kind of charge rate.
I agree that batteries need to get better over time, and so do L2 and DCFC charging networks, but this isn't going to be magically solved with a better battery that just pops onto the market. Even solid state will take many years to mature, and our grid will need a lot of upgrades before multi-MW charging stations can be built in many places. Might as well do what you can now and enjoy the benefits, perfect though they aren't.
