Wheels
ANP52yrz
James
Washington
2023 Mach E Route 1
Aircraft Mechanic
Just got a 2023 Route 1 with original ugly 18” wheels. Would like to swap out for factory 19” wheels. It shows 2021/22 wheels don’t fit. Do I need 2023 19” wheels only?
markboris
Sonora, CA
No. You can use any year Mach-E 19" or 20" wheels on your Route 1.
dww
Doug
Vancouver, WA
1999 Jaguar XJ8, 2000 Ford F250 SD XL 4WD
Winemaker
Are you near Portland OR/vancouver WA? I have a 2022 Premium and downsizing to 18
dww
Doug
Vancouver, WA
Winemaker
Ps I’m getting aftermarket rims in a few weeks
ANP52yrz
James
Washington
2023 Mach E Route 1
Aircraft Mechanic
I’m in Washougal. Why you down sizing?
dww
Doug
Vancouver, WA
Winemaker
My wife want's a little better ride. Here car is a Lexus but we drive my car more often. We installed new springs last year (Eibach progressive fronts and softer rears) but that was not enough so I thought I would try 235/60/18 instead of the 225/55/19 and get a grand touring tire.
I only have around 7500 miles on the OEM tires
Wow, you are so close......I know this forum is not for trading/selling so if you want to talk/chat more I'll give you my email/phone. We are back in Vancouver in 10 days.
dww
Doug
Vancouver, WA
Winemaker
ANP52yrz
James
Washington
2023 Mach E Route 1
Aircraft Mechanic
Let me know when you’re back. Sounds good.
ANP52yrz
James
Washington
2023 Mach E Route 1
Aircraft Mechanic
Still interested in the 18” wheels?
dww
Doug
Vancouver, WA
Winemaker
I decided to put on 245/55/19.....bigger diameter tire than stock that gave me the same sidewall height as the 225/60/18 on the Select. You can have the old 19's after I do a few more tests on rubbing since I lowered the car with Eibach progressive springs. I did notice a little wear on the sides since I had the PSI lower.
