Where are the 2024 GTs?
dpnelson
Ford Fusion, Mach E soon?
The GT prior to 2024 has the BW motor unit in both the front and the rear. According to the stuff I've seen about the new motor, it is only going into the rear on the GT. This would indicate that the front motor unit on the GT is still BW. It would follow that since Ford is still purchasing that unit the rear motors on the Premium and Select are this same unit. Then again, I may be completely wet. I get wet when fetching ducks and geese. ?‍♂?
Maybe, but it's likely the rear motor update also comes with other updates like a new inverter, updated motor frame, and updates to the brakes (assuming the new motor doesn't have a parking pawl). I'm not sure they'd want to have that level of variability in the production line, especially if the new motor is less expensive being an in-house design.
It's possible that the delay for the GTs is that they're not done redesigning the front end layout for an updated big front motor. It's also possible that there are other GT needs being addressed in the Job 2 update, such as bigger busbars in the battery pack or a redesigned HVJB. Those things probably need to happen to totally get rid of performance throttling.
Mach1E
If people have build dates of next month (April) already, the design work has gotta be way done at this point.
They’ve already hinted months ago that the performance throttling isn’t a problem on the Rally. So also betting that the design plans are done there.
We shall see when the first ones show up in May.
  • Like
Reactions: SWO
SWO
MD, USA
I know the front and rear motors on the GT aren't interchangeable. For one, the front motor has the inverter integrated with it I believe.
Unless there's a production contstraint, I can't see why they wouldn't put the new rear motor in every 2024 (maybe Job 2?).
