E90alex
- Feb 17, 2025
- Seattle, WA
- â25 MME GT
Exactly. Itâs needed to close the contacts.All it needs to do is close the contacts and its job could be over. That fires up the power supply that takes over. You do not need a 12V lead acid rechargeable with CCA's to close the contacts. With some 12V lasting only 3 years it indicates that the 12V has a much higher workload than putting 12V across contacts.
The question wasnât about how big the 12V needs to be. Just that all EVs still need some type of LVB matter what.
The 12V dying prematurely is a combination of it being lead acid, being super tiny so it gets cycled more, and poor charging/management strategies by Ford (especially in the beginning).
Tesla for example uses a Lithium LVB now which helps mitigate premature failures. Teslas are also programmed to close the HVB contactors for every little thing so the LVB is not used for much other than for standby and flipping the HVB contactors. Ford relies on the LVB for everything until the ignition is turned on (or using remote climate or when actively charging).
