Windows and Mirrors not Working
ChuckA
Chuck
North Branford, CT
Accountant-Retired
I just unplugged my MME from my charger and after backing out of the garage discovered the door controls for the mirrors and windows weren’t working.
Shut the car off, restarted it. Still not working. Any suggestions about a fix?
Make sure after shutting off the car, you open the door and let everything power down.
If it still doesn't work, let it sit for 15 minutes or so. If it still doesn't work, pull the negative battery cable. Or just head to the dealer.
Also, try multiple doors. And try using the remote if you have PaaK.
zhackwyatt
JSeis
AWD Select
I had a similar problem in that my side panel mirror control stopped working. I checked window control and all worked (I foolishly did that on a drizzly morning, fortunately no issues).
I notified the dealer to include that in the scheduled 10,000 mile service. But the mirrors started working 3 days later (3 charge cycles) and no issues afterwards.
ChuckA
ChuckA
Chuck
North Branford, CT
Accountant-Retired
This is a known issue
As others have said, it should work after the modules have a chance to go to sleep and reset.
Seems to be a startup/sequencing issue.
After driving to my destination and letting the car sit 20 minutes, it started working again. I think that the car may have been doing an update. I did call the dealer and the 1st thing they said was to come down so they could load an update.
Js1tr3
Jason
Ann arbor mi
Mme awd std range
EES
same thing here, went to roll down the windows and couldn't. was able to roll them down with the phone app.
method93
Philadelphia
2022 Premium Standard Range Rapid Red
Same thing with me this am. Window and mirror switch not working. Letting it re-set and we’ll see. Car has less than 200 miles on it. To think I picked on my friends Tesla for initial build quality @Ford Motor Company
Software glitch. I had this issue over the weekend for the first time in 36,000 miles. It resolved itself after a few key cycles. Weird.
