2021-2023 Ford Mustang Mach-E Will Get Sync 4A Update
bbulkow
menlo park, california
Honda CRV
Oh ok. I am not even sure If 6.2.0 is ahead or behind 6.14. I came to Ford from having owned a Tesla for the past 3.5 years and the updates were pretty simple. Tesla would release an update with a numeric sequence that represented the year of release, the week number of the year, and the revision number. How hard is it for Ford to come up with something similar? Everyone would be able to easily determine how far behind they are but with Ford I see they made it quite complicated. :(
The system Ford uses is called "Semantic Versioning". It is widely used across a very wide number of software systems and has been for decades. https://en.wikipedia.org/wiki/Software_versioning (scroll down to semantic versioning). 6.14 > 6.2.0 because 14 > 2. 7.1 > 6.15 because 7 > 6. This is common in software because linear systems (like tesla uses) fail in the face of more complex systems where you need to execute minor changes on important field-released versions (eg, someone with 6.2.0 will take 6.2.1 for a safety issue but doesn't like the UI changes in 6.8 and won't take the latest).
If you use a cell phone, you've got semantic versioning. "Android 14" is 14.something, and you can continue to get security updates even if you don't move to Android 15. Same thing with IOS - Apple has several release trains running at the moment, and executing patches and minor updates across their entire version system. It also makes hardware changes harder - like if there's a new generation of in-car CPU but it only runs recent, and you need to apply safety patches to older cars. You'll end up with 2.x for some cars, and 3.x for newer cars.
Tesla, being Tesla, appears to have ignored software best practice and used linear. Linear has some advantages, and is actually in use more and more (Microsoft Windows uses it for sections of their code). While it seems easier to you, and is simpler, it restricts both developers and users, which is why decades of software systems have used semantic versioning. Linear is easier *if you don't have a complex range of hardware and a big product line* - leading to faster developer velocity and faster patch releases - but leading to eventual failure because the business as a whole doesn't scale (eg, would Tesla Trucks be on the same release as Tesla Cars? Or would you need two teams replicating exactly the same functionality, one for Tesla Trucks and one for Tesla Cars, even if a number of components are the same and some are different?)
Perhaps all those millions of developers aren't dumb, and maybe Ford did a good thing by staying with industry standard practice?
6.14.x? Heh, still on 6.8.x here. I guess I could go and see if I have an IPMA or anything else via FDRs, but even the recent powertrain updates that fix the disappearing 1PD doesn’t turn me on (since I drive 2PD and I haven’t seen a “Drive Mode not Available” in a long time). ?‍♂?
burritoman
2023 Mach-E Premium, Ford Edge
Mine just got 4.2.4 a few weeks ago. Is there something wrong with my car that it's receiving old updates?
Edit: never mind, I found the thread on FDRS lookups. I can check it out there
Chainspell
Erich
Sacramento, CA
'21 Premium 4X, '23 GTPE
From the chatter on this forum, it seems that a lot of '23s (mine included) have not had an OTA update since early March when we received the Tesla charging access update. Perhaps this is the reason to re-announce it.
I got the same one on 3/6 and nothing since. It seems to be a pattern for the 23 models.
I have a 2023.0 and received 6.14 OTA late April, but I have the updated gateway module (via FDRS) which supposedly helps you receive updates faster. (Not in early access)
Aahhcc11
Y
Mach E Premium Nite Pony
Can someone point me to the thread where I can see how to decipher what version I have?
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
Only real way is if you have a PU notification in the Ford Pass app.
azerik
I went back to look for my FP PU notifications, last one the app got was 6.1 in Oct, so i could be further back than I thought. But my 1PD still works so it's got that going for it I guess.
Coming soon(TM)
Well, i did finally get a frunk button in FoodPass and the pillar short cut.
The sync screen button won’t appear until you get the fabled and mythical 6.14 update.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Did you click on the link he provided with the dogs breakfast of updates? It appears it is pretty hard. Here They use what is called "Semantic Versioning". Been used for decades ? Very straight forward and intuitive
Still on 6.4 and a tesla see no path forward in getting 6.14 any time in the near future.
iam-s-Hon
Richard
2021 Job 1 MME Premium AWD ER Iconic Silver, 24 Lightning Lariat AMB
Given how long frunk button took, 2025 maybe? ?‍♂
elmedico27
Drew
Missouri
2022 Mach-E Premium AWD ER
And to complicate matters, I found out this week that if you go back and forth between the “new” FordPass and the old app version, the most recent software update it shows you will be the most recent update you received while using that particular version of the app. So I see a different “most recent” update depending on whether I’m in app v5 or v4.
