2021 Mach-E not receiving OTA updates
rugedraw
Javier
Miami, FL
Auto Sales
For the first time ever, after modules update and the rear camera recall by the dealer, I received an OTA update
But still no BC subscription
I have also era led power meter from ForScan, but There are a plenty of gray bars
Well, that sucks. That means that what we did didn't work. A successful OTA syncs the vehicle up with the server. I just checked your VIN and you still do not show the ability to subscribe to Bluecruise. That means there is other config that needs to be fixed aside from what we did.
buddabest27
buddabest27
Italy
Mustang Mach-E 2021 Select RWD Extended Range
What We could do about?
Now I’m a bit happier about this car
Tomorrow I will also try an Android Box on the car because I would like a starter infotainment
I have also noted that the car is better on craters on the road after the update
rugedraw
Javier
Miami, FL
Auto Sales
I'll have to go through the IPC config on your car when I have time to see if I find anything else that's misconfigured for BC.
buddabest27
buddabest27
Italy
Ok, I’ll wait for that Then :)
But it’s possible that could be a problem about navigator map’s update missing?
Because I noted that, but the dealer tells me that it’s better use CarPlay or Android Auto for maps
rugedraw
Javier
Miami, FL
Auto Sales
Are you saying you have no navigation maps or no BC maps? If it is just no BC maps, then that is normal since your car is not properly configured for BC.
buddabest27
buddabest27
Italy
I have no BC maps, but also Navigation Maps are not up to date
Aulander
Italy
Mustang Mach-E Premium AWD
@Aulander in Your Mach-e is available the BlueCruise or not?
I’m trying to do some modifies with FORScan and I need another VIN to compare with mine..
No BluCruise availability on my Mach-E even if I got the BC update SYNC 24.2.1.6.2.
Ford assistance told me that in Italy the BC subscription is available only from MY24.
buddabest27
buddabest27
Italy
My dealer told me from MY23 because before that the car haven’t the hardware.. But I think that is a wrong answer
But probably they didn’t enable the subscription in Italy for MY21…
Do you have the warning about watching the road? Because after a mod with FORScan, I have it
Ark29
Ark
Netherlands
2021 Ford Mustang Mach-E
Employed
Are you referring to the “Driver Alert” (Driver Distraction Warning)?
Ford Mustang Mach-E 2021 Mach-E not receiving OTA updates IMG_8263
buddabest27
buddabest27
Italy
Yes
I already had it with the warning “keep hands on” only, but three days ago with FORScan and @rugedraw ’s help, I now have also the “Watch the road” alert that I didn’t have before.
Aulander
Italy
Yes, I have the warning about watching the road after the BC update 24.2.1.6.2. Unfortunately Ford didn't enable the BC in Italy for model years before 24 and I think it is not possible with Forscan because it requires a server side activation by Ford.
rugedraw
Javier
Miami, FL
Auto Sales
If there are no Mach E's of these model years with working BC in Italy, then nothing you do with FORScan will work to get it to work.
@buddabest27 You can change the config in the IPMA back to enable traffic jam assist if this is the case. Once Ford makes BC available in your region, we can revisit this then.
Ark29
Ark
Netherlands
Employed
Yes
I have this already in my car but no BC and no OTA. I see this warning works randomly.
buddabest27
buddabest27
Italy
It’s a shame..
Maybe it’s possible to “spoof” the car out of Italy? With also the use of an abroad Ford account..
I don’t think so..
Yeah, I'll revert with the backup file that I made before..
Do you have any pending recall? Because probably you have some old modules version that blocks OTAs
When I went to the dealer, I told him that I would update everything, even if I have to pay.
Luckily, every update was made with the recall
Ark29
Ark
Netherlands
Employed
It’s a shame..
I don’t think so..
No pending recall. The one for the doors was carried out in September. Dealer updated everything that time.
