2021 Mach-E not receiving OTA updates
a4tech
Pawel
IL
Mach-E '21
Can You share Your latest EU software numbers for
IPMA / ECG ?
buddabest27
buddabest27
Italy
Mustang Mach-E 2021 Select RWD Extended Range
@Aulander @rugedraw
In the se days I received the SYNC 24269 revision 1387 with BC 1.1E
Ford Mustang Mach-E 2021 Mach-E not receiving OTA updates IMG_5278
I also found a bug probably
When I stop the car I have 1km/h ad ground speed even if I’m completely stopped
It has been resolved with other up
dreKion
Alfonso
Spain
Mach E AWD ER+
I received the BC-25.DC update last week, it installed fine, but I lost cruise control with lane keeping assist right after updating.
I haven't received the new sync interface yet.
buddabest27
buddabest27
Italy
Where do you see it?
On SYNC?
wappla1911
Austria
Ford Mustang Mach E 2021 Job1
Same here...
dreKion
Alfonso
Spain
Mach E AWD ER+
On SYNC?
BC-25.DC yes on sync
The cruise control buttons are on the screen, but on the highway the left and right circles aren't displayed, only the green bars.
If I turn off lane assist using the steering wheel controls, when I turn it back on, it gives an error message saying it's unavailable.
buddabest27
buddabest27
Italy
My acc and lane centering works fine even with the update..
Have you try to use FORScan to check DTCs?
buddabest27
buddabest27
Italy
Hi
Yesterday I noted that OnePedal Drive has some problems
When I’m slowing down releasing the throttle pedal, if I hit a road bump or similar the car stops slowing down and regen and did some meters without any brake and Then it restart braking
It’s very dangerous..
It’s a known problem? Because where I live There are many road bumps and craters and I’m a bit scared now…
