2024 Range Improvements
dpnelson
Ford Fusion, Mach E soon?
There are now enough 2024 EPA stickers floating around that we can get a pretty good picture of the range and efficiency improvements.
First, the bad news - Standard Range models (LFP Pack)
Modelyeartotal MPGecityhighwayrangekwh/100 miles
RWD SR20231011079525033
20241021069825033
AWD SR202393988723036
202491958823037
Numbers are flat to slightly worse. Overall, City MPGe declines slightly, and Highway shows slight improvement. Range figures are unchanged
The good news - Extended Range Models
RWD ER2023991059231034
202410611110032032
AWD CR12023981059131234
AWD ER202392978529037
2024991039430034
GT202384907727040
GT PE202382887626041
GT w/perf202490958528037
Numbers are improved across the board. City MPGe improves by 5-6, and Highway by 8-9. Range is up by 10 miles for like models, or 20 if you consider the 2024 GT the successor to the 2023 GTPE. (Note, the 2024 GT numbers are from one sticker posted to this board. It's unclear if the numbers are any different without the performance option)
Interestingly, the changes in these numbers are not internally consistent. The range figures improved by considerably smaller amounts than any of the other numbers. For example, the AWD ER had a 6.2% increase in city MPGe, a 10.6% increase in highway MPGe, a and a 8.1% decrease in kwh/100 miles, but it only shows a 3.4% increase in its range figure. It will be interesting to see what some of the more consistent third party reviewers report when they run their own tests.
Billyk24
William
PA
Do the 2024 models have the same tires/sizes as the 2023/2022 models?
This sounds like relaxing the EPA test procedure to get better results. AKA Tesla. Unless there is something that has changed to justify the improved efficiency, I call BS.
LincolnLuvr
VA
currently car-less, but hope to get a MME!
There's no updated range for the 2024 GT (without performance upgrade)?
Yeah, hard to believe an increase in efficiency without changing the hardware.
GT possibly has a new motor, but the rest of the lineup seems the same.
Maybe the new wheels come with new tires that could help some?
But I bet it’s a testing change. I wonder if they switched to the 5 cycle test that Tesla uses that inflates the results.
dpnelson
I'm wondering if the new motor is being put on all of the models with extended range. That could explain why those models had their numbers improve, but the standard range ones didn't. I would expect a testing change to affect all models similarly. Plus, Tesla had to reduce their numbers downward for 2024, so the 5 cycle test may not provide an advantage anymore.
The other thing that might explain the discrepancy is if Ford/LG reworked the extended range pack to have lower internal resistance. If you look at a picture of the pack internals, it has a lot of long, relatively skinny busbars between the modules. It's entirely feasible that they could have worked with LG over the last 3 years to update the cell and module dimensions and orientations to get to a design where they could have shorter, thicker busbars. It's also possible that the cells themselves have improved, and have lower internal resistance.
kodiakng
2023 Cyber Orange 4X Mach-E
we already know there is a new motor in the rear at a minimum (front in GT+rally) and improvements in the coolant loops as @Mach-Lee has noted so these small improvements in EPA range could easily be seen there. i haven't seen any details on the NMC battery pack but could easily see improvements there too - especially if they're overcoming the 5-sec barrier.
superdave80
Santa Rosa, CA
2022 Mach E Select SR RWD
We would most likely see way higher gains if they switched to the 5 cycle test.
Arsenic17
Arsenic
Denver, CO
MME GT 2023 Vapor Blue
Perhaps they are changing the BMS to allow for more usable battery? Or they tweaked the testing procedure some to give more favorable numbers? Cant imagine there being much difference like this from 2023 to 2024. The only changes are wheels (and perhaps tires), but don't see that making this much difference. I also dont think this is Ford changing to the same EPA test Tesla uses that inflates their range so much, but it could be.
DevSecNetOps, General PITA
Eruption green flys through the air better with the gold grille
Mrn
Pima County
MMES
Aviation
I suspect if they showed a +/- error range for the measurements the overlap would show the difference is not mathematically significant ?
