30% battery use for 78 miles.
timbop
Might not seem too impressive but it's a SR AWD so that works out over 240 miles and it was 65 to 75 almost all the way.
260 actually: 78/.3 = 260
It is hilariously awful that in this use case 28% of the energy source was used not even propelling the vehicle. I know EVs have compromises but that's plain terrible. And that's before freezing temperatures.
I guess that you weren't aware ICE cars use at most 35% of the energy in gas to propel them, with the rest being wasted as heat?
Coffs
PA
Mach E, Explorer, Busa
I guess it's not as obvious, you know the mpg but not how how it's made up. The breakdown of what's going on with an EV just puts it in your face more.
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
The difference is that EVs are wildly efficient in comparison to gasoline. When it's wildly efficient, outside influences have much more impact on the overall efficiency moreso than gasoline.
Gasoline by comparison has much less overall efficiency impact because it's already wildly inefficient.
alexgorod
Alex
DBA
The positive thing about this experiment is that I don't need to worry about my accessories taking anything from my range. With them or without, it's still the same.
Interesting. I'll disconnect all tomorrow to see if it goes to 0.
You're not following.
What does your center display run on? 12v
What does your instrument panel run on? 12v
What does your ___ run on? 12v
Those are all ACCESSORIES, except for climate.
At least that's my understanding.
alexgorod
Alex
DBA
I think I do :) and I agree with you. But I want to figure out where the difference between 2% that @Coffs reported and my 7% comes from because he has all these accessories that you've listed. The only thing (and I suspect it's the highest energy consumption) is charging the 12V battery, that is very low or non-existent right after charging the HVB, and that is not a condition in my experiment. This part will happen tomorrow ;)
Coffs
PA
I started with 100% charge so hopefully my 12v battery was charged during the HV charging period. Leading up to this I had the dreaded 12v battery warning low level once a week, this was the first journey over 15 minutes long since getting the Mach E.
LM_COGT
Brandon
Colorado USA
2023 Vapor Blue Mach-E GT, 2019 CX-5, 2018 Leaf S
EE
My experience is that heated wheel/seats get put in the Accessories bin, and not Climate.
Don’t forget the radiator fan, that’s part of accessories and can draw a lot of power. Same with rear defrost.
Dang. I got 2.2 mi/KWh on my way to work this morning in traffic. Of course the traffic was trying to push me past 75. ??
EDIT: I should note that I was the slow poke on the freeway. ?‍♂?
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
One does not simply, drive better. lol
JSeis
AWD Select
I commute 90 miles RT a day. Rural 2 lane. Averaged 4.1 mi/KWh for the last 1800 miles.. ever since it warmed up to 45-54 degree mornings and 62-64 degree afternoons. 68 KW Battery at 93.5% health and 48,000 K on the odometer. Typically takes me 54 minutes one way on roads varying in speed from 25-55. Pretty hard to go much faster than 57-58 given state patrol, winding roads. The MME can be amazingly efficient.
A few months ago ?ice ice baby!
Ford Mustang Mach-E 30% battery use for 78 miles. IMG_9176
Yesterday I was recording my Trip 1 and Trip 2 data, in case my service appointment (Lightning) reset everything.
I noted that it was showing 7% due to Accessories. My AC and fan were off, as was my radio. My ventilated seats were off. The only "accessories" I used, other than having displays on, was to open the sunroof shade and the driver's window.
The drive was only 7 miles, but it goes to show how the lack of clarity in this information makes it confusing.
On short trips, the % attributed to accessories always seems high.
