80 amp wall charger pro
Junior
Trevor
Canada
F350, Edge ST, Mach E
I want to have a hardwired wall charger in the garage and keep the one that came with the mach e in the car. I have a chance to get the 80 amp at a good price just wondering if it'll work on the mach e. It can be knocked down to 60 amps if 80 is too much. Will it charge the mach e or should I just pass on it?
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2025 Mach-E Premium ER
The charger will work. This is the selector switch for choosing the maximum amperage.
Ford Mustang Mach-E 80 amp wall charger pro Captur
Just know that whatever you set the charger to, the most your car will draw is 48A.
Polar
SBJ
PNW
2021 Select RWD SR
Wire it up to 100 amps if possible - some day you’ll have that 19.6kw capable vehicle!!
Almost a decade ago…geeze; I installed a 6.6kw EVSE when my Leaf at the time only was capable of 3.3 kw.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
I am just learning, but FWIW
L2 (240 volts) charging on the Mach E is limited by the car to a max of 48 amps. An EVSE capable of delivering more will still only deliver a maximum of 48 amps to the Mach E. But in case the OP ever gets a car that can charge at a higher rate, having a higher amperage circuit could be useful. Of course their electric service and panel need to have sufficient excess power to make that feasible…
kkgg
Minnesota
mach e
Thanks for explaining.
Junior
Junior
Trevor
Canada
Junior
Junior
Trevor
Canada
Yes that's exactly what I was thinking about down the road. At least my option is there. Sub panel I have in the garage is 100amp
Junior
Junior
Trevor
Canada
Thank you all for the quick replys and information. ?
kkgg
Minnesota
mach e
Sightly of topic here but,
What happens if I connect to a 240v outlet 50 amp, but the EVSE is only rated to 32 amp. Will EVSE just draw 32 amps regardless or will it get over heat
Vulnox
Livonia, MI
It will just draw up to the max it's rated for. No different than plugging in a lamp to a 120v/15 amp household outlet and it only drawing what is needed for the bulb. 240v doesn't work any different other than capacity differences.
You could plug a 32 amp EVSE into an outlet wired for 100 amps and it would still just draw what is needed. It's not a firehose, where water pressure is a direct force coming out the other end, it's more like a river and your outlet is just taking a drink from the river bank. A wider river doesn't mean you are forced to drink more.
Junior
Junior
Trevor
Canada
Great analogy, I'm slowly "picking up what what everyone is laying down" here. So much to learn and understand on the EV's .
kkgg
Minnesota
mach e
Your analogy totally makes sense for this usecase. ?Thanks for replying
