Anyone know actual size, bolt pattern, offset, etc?
ok, Info I was able to get from the CA wheel site, for my AWD Select is:
2021 Ford Mustang Mach-E 4 Dr Sport Utility Select + change vehicle
Size Bolt Offset bore OE Tire L/S Type Thread Hex TPM
18x7.5 5x108 38-53 mm 63.4 225/60R18 104/H nut M12x1.5 19 Yes
stock tires 225/60R18
....I am wondering if anyone has actually measured and verified these numbers for fitment? I am particularly concerned with the 5x108 bolt pattern as this severely limits choices...
once we know for SURE, then I'd be very interested in seeing a list of available wheels, and sources for after-market. I usually shop hard for lightest wheels, but at 'reasonable' price being something less than $300/wheel.
Wildthing
Canada
Mach-E Premium SR AWD
Those numbers are confirmed. Some as received their cars in Quebec and already installed aftermarket winter wheels with those specs
ClaudeMach-E
Claude
Quebec Canada
Mustang Mach 3- Tempo- Malibu(3)-Actual Kia Sportage AWD
What is the 63.4 number?
So we have Wheel size 18 X 7" Bolt Pattern 5 X 108 Wheel offset 38-53 mm and the bore is it center or is it 63.4 ?
Thank you
Fat Mach
Nor Cal
2013 GT350
Does that offset suggest that the front and rear wheels are different, and we can't rotate them front to rear?
ClaudeMach-E
Claude
Quebec Canada
I've read somewhere that 7 inch is the max wheel width for 225 tire width, that means you plan larger tires for winter.
I found this chart on tyresizecalculator.com. It looks like 8" wheels are actually a better match for the 225 width tires.
Ford Mustang Mach-E Anyone know actual size, bolt pattern, offset, etc? 1611870169809
kdryden99
Richard
Montreal Canada
The offset range i believe will help going to 245 tires
Thank you
63 is the bore dia.... presumably the suggested minimum for clearance around brake calipers
The bore is hole in the center of the wheel, which doesn't really have anything to do with brake caliper clearance. You just need to make sure that any aftermarket wheels don't have a bore diameter that's smaller than 63.4mm. Bigger is okay because you can just use hub ring spacers to take up the difference.
