Anyone noticing range issues yet?
Greddy1
2021 Ford Mustang Mach E Grabber Blue First Editio
Sales
Hi all I have noticed here lately that my miles at 90% which is the normal charging I do has dropped about 25 miles. When I first got the car, range at 90% was always 250 miles and 270 to 300 when the weather was warm at 100%. Now it consistently is in the 220 range at 90% Is there a conditioning that has to be done on these to maintain my range? I'm concerned I've only got 12,700 miles in a year and 3 months on this and already losing range? I also can't get past the 2.7.1 update so don't know if there is any software updates that address this?
AKgrampy
Fairbanks, Alaska
Have you noticed any change in your average mi/kWh? That is what I would go by more than the range estimate. Also I know Ford is rolling out a new range algorithm but my understanding it is only out to the EA crowd but I could be mistaken.
Anton
Anton
Fresno, CA
2021 Mach-E AWD ER
Yes. But I did get beefier tires and 20" wheels. Going slightly uphill and northbound against the wind in hot Cali with AC blasting - 1.7 mi/kWh. The other direction - 2.2 mi/kWh. I'm running near 40-41 psi. Not sure what's up...
255x145r20
Brian707
2021 Infinite Blue Mustang Mach E Premium AWD EXT
I'm stuck on 2.7.1 too. I wouldn't worry about the GOM estimate, I would check the m/kwh as the above poster said
Brian707
255x145r20
That is your answer
Mirak
Kansas
Going off the GOM (Guess O Meter) or trying to guess how that algorithm works is pointless. Miles per kWh is what you need to track. If you are seeing a meaningful drop there based upon similar routes and temps headwinds, then you should be concerned, but I highly doubt it. I’m 16mos and 18k into by Job 1 and I haven’t noticed a smidge of range reduction.
hbirring01
Baltimore, MD
2021 Ford Mustang Mach-E, 2025 Rivian R1s, 2021 Tesla Model 3
I noticed the same. Its getting better and back to normal (SR AWD Select -> 230 miles @90%) but my mi/kwh has gone from 4.0+ to 3.7. Same driving habbits
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
We are averaging 3.5 miles per kWh at 12 months and 9K miles. I think the GOM got more conservative after getting CSP 21P22 applied. I haven’t seen it go over 300 since then but actual mileage hasn‘t changed.
TD1273
Mel
Spokane Wa
2017 Ford F-350
255x145r20
That would do it. Bigger tires are always a problem on any vehicle for mileage
Greddy1
Greddy1
Sales
I have not paid attention to that but will now. Is the a standard I should be looking at if the mi / kwh is at max output?
Richard L.
Richard
West Babylon NY
2021 Mach E First Edition Grabber Blue
Last summer I was getting 270 miles with 100% charge. Now it’s 284 miles with improved mi/kWh efficiency. Driving habits the same. Possibly related to one of the many software updates?
Greddy1
Greddy1
Sales
what update are you on?
AKgrampy
Fairbanks, Alaska
I believe the mi/kWh is the most accurate measure of how your Mach is performing. The range is just an estimate which, as I mentioned, Ford appears to be trying to improve. As we approach winter, unfortunately not that far off here in Alaska, I will reset my driving history as the average mi/kWh will drop and I will want to get rid of the summer driving info. Right now my average is 3.7 mi/kWh. My range indication is about 15% under what I am actually achieving. I only drive around town and charge every other day so the range does not matter much to me. Once they get another charger or two along the highway between Fairbanks and Anchorage I will give that a go and see how range and average mi/kWh compare. From my reading I know they call it the Guess O Meter but I would like to get a feel for myself.
