Bba
- Ben
- Oct 4, 2023
- tx
- Mach E
no disconnection, just tapped into the tweeter speaker signals since that is full range. the capacitor for the high pass is right at the tweeter so if you spice in before that, it is a full range signal. Then use that to feed into a line converter ( I used a JL Audio LOC 22). All nav, chimes, etc still work.Did you just disconnect the amp in the back? And when you say you got full range signal from the front tweeters, does that include nav, warning sounds and chimes?
good luck!
