Audio Upgrade Mach E
21st Century Pony
Martin
Arlington, Virginia
Chapeau bas!
Rayne
Mach-E Premium AWD ER
This is so dmn beautiful makes me wanna cry ?
MyLittlePony2022
William
SF Bay Area, California
After months of planning and late night work in my garage, I’ve finally completed my project. This is an elaborate install, but nevertheless turned out to be pretty clean and rewarding. This is definitely not for the newbie, but you can see what the potential is on these new EVs. I believe it is the perfect platform for installing car audio; you can run the system for days as the whole car undercarriage is a battery(no need for extra batteries, capacitors, or high output alternator), voltage is constant (no more lights dimming when the bass hits), no carbon monoxide so you can keep your garage closed while you test or blast the audio.
I started with downloading the manual online from factorymanuals.com. It’s a large file, but you will need this in order to know how to remove panels and access the necessary wiring. My plan was to use the large 15 inch screen as the audio source/controller and upgrade everything else while keeping a factory/stealth look. Here’s a list of the major components:
JL Audio LOC22 Line converter for factory signal
JL Audio TWK 88 - Front stage dsp
JL Audio D8 - Rear stage dsp
JL Audio RD900/5 - 3 total, sub channels; 1 for each sub, then hi pass for the mb/mr/tw front, mr/tw rear
JL Audio 13TW5 - 3 total
Morel MT300 - 1 pair tweeters (front)
Morel MM3 - 1 pair midrange (front)
Morel SCM634 - 1 pair mid bass (front)
Morel Integra 624 - 1 pair 6.5” coax (rear)
Total System Power 2700 Watts (500W to each sub)
-Ben
@Bba Thanks for posting this. Give all of us weekend warriors something to strive for on our "next" install.
Been waiting a bit but plan to upgrade to a new aftermarket amplifier. Thinking of going with a AudioControl D-6.1200. This gives me the amp with DSP built in. Going to put it in the rear panel where the old amp is located. Don't want to lose space.
My question is what did you do to convert the digital factor signal for the aftermarket amps. I did not see what most people use (PAC Amp Integration Interface - AP4-FD31) for that conversion on your list of components. If you could share a bit for those of us that are ameature installers, it would be appreciated.
Bba
Ben
tx
Mach E
My system outputs were just analog so just tapped into the front tweeter outputs for the full range signal. If you have the B&O, that has dsp so you will need to sum those signals into a processor like the JL Audio Fix series to get a full range audio output. I'm not as familiar with the Audio Control D series, but that may have the capability of summing the dsp signal and reprocess it into a flat signal for you to customize. That would make it simpler and fewer components to install. Happy installing!
Doc
Les
Georgia
2023 Red Mach-E GT
Psychologist
MyLittlePony2022
William
Thanks for your response. Yes, I forgot to comment that I have the B&O system so the front tweeter signal inputs are analog and front mid, and combined rear speakers signal is digital, so you have to convert the rear signal to analogue. This assumes you want to have fader control, which I do.
Yes, the Audio Control D series allows you to flatten the signal and them customize. You can also connect a aftermarket sub with amp to control and modify the sound.
@Bba how did you get balance and fader control on all the speakers with just a single channel input? The DSP will allow for delay which gives you balance. How did you fade the front and rear speakers?
Bba
Ben
tx
Mach E
I took the left and right tweeter outputs to get the full range signal that feeds into a 2 channel JL Loc line converter. From there, it feeds into a JL Audio TWK 88 for the front channel and then daisy chain fiber optic into a JL Audio TWK D8 for the rear channel. I have separate knobs to control front and rear, including the sub. This gave me more flexibility than the stock fader. The TWK are both DSPs to do all the time alignment, phase, crossover, and eq. It's basically a 3 way up front and a 2 way in the rear. It's overkill, but I like it.
I disassembled all the doors and trunk area to apply sound deadening material to keep rattles to a minimum (the rear outside wing still rattles, will get to that later). After several measurements, calculations, and drawing revisions (on sketch up), I decided to go with three 13 inch JL Audio subs for their shallow mount and minimal air requirement. As you know, there is no spare tire since the trunk cavity is very shallow, the subwoofer options were limited. Fortunately, based on my design and calculations, 3 of them would work (2 would have done it but that would have been too easy). I built the subwoofer box with 3/4 inch mdf and used layers to build up around corners of the well. Each sub has its own chamber and equal in volume. There are multiple layers of panels to achieve a stock look but still give it a premium feel. Different layers of finish were incorporated to match the interior vinyl texture, carpet, and gloss black trim (vinyl wrap). The cover has a breathable grill covered in carpet so the trunk is still usable and factory looking.
For the front doors, I dropped in 6.5 inch Morel carbon fiber midbass and then 6.5 Morel coaxial in the rear doors for fill.
The front A-pillars were completely fabricated to accommodate a 3.5 inch midrange and 1 inch tweeter. The factory location for the tweeter on the dash was a decent location but I felt the midrange needed to be higher and forward. Since I was already building that, I might as well incorporate the tweeter with it. I made an mdf plate to hold the MR/TW combo then glued/screwed it to the plastic A-pillar. Then I wrapped it in a spandex type cloth to achieve a molded look. This gave me a base to apply resin and fiberglass. After multiple bondo fills and sanding, I wrapped it in diamond textured vinyl to match the dash (same as the sub panel). I made a pressed grill with a chrome edge finish to match the chrome around the dash and door panel. Not sure if I will wrap the grill with cloth to match the doors as I like the look of the grill but still looks factory.
I decided to mount the amps and processors in the frunk since the battery is right there. But I had to punch a larger hole through the fire wall to accommodate all the speaker wires from the frunk to the interior. Although there is a lot of room in the frunk, I had multiple iterations of the design in order for everything to fit and still have the frunk functional. The battery was easy to access and I was able to tap into it easily and kept the connection to only a few inches from the fuse bank. With everything being so tight, I had to make my own rca cables with 90 degree connectors in order to complete the install. I made all the panel covers to the electronics so no screws were visible, so I made the top center logo out of acrylic with magnets to cover the main screws. All the grills were pressed with beveled edges to give it character and I attached a mustang emblem to make look more factory.
Most of the electronics fired up on the first go except for one bad amp and coaxial. After getting the components replaced, I fired it up and started to tune the system with a calibrated mic and a laptop. I spent a lot of time researching speaker components for their parameters and frequency charts and they were worth the time and $. After applying the time delays and checking for phase, I started to adjust the crossovers and frequency response. Very little adjustments to the frequency and gains were done since the initial response was quite good.
The results, unbelievably clean fidelity. The front stage is incredible, balanced, and most of all, no fatigue. And if I want to crank it, it hits pretty hard.
I hope some of you audio nuts find this useful for your next project.
-Ben
OMG! You’ve DESTROYED the koi pond! You’re a MONSTER!!!
All joking aside, this looks impressive. Definitely not something I’d do to my own car (gotta think of the koi!) but still incredibly impressive!
Okuma
Nate
Atlanta
2022 Mach-E GT Grabber Blue "Blucifer"
@Bba I've read your post about fifteen times today. This install is so well thought out and beautiful, to say the least. Now I'm checking my bank account to see what I can do?
What made you decide on coax rather than comp in the rear?
Bba
Ben
tx
Mach E
The rear is just fill. After months of listening, I could have just left it stock. I believe in just front stage stereo channels is all you need. The rear is just to add some spatial effect if you like that, but it doesnt need to be so high end, imo. I would definitely not upgrade the back next time, even though I went over the top on everything else.
Dadstoyy
Edge1071
2022 Mach E GTP
Director
Very clean. I am running 1800 watts in mine with the PAC audio amp pro and 2 audio control amps. I replaced all my speakers in the car. My challenge kept happening with tapping into the factory amp. So now that I have the amp pro I was able to remove the factory B&o amp and run all my stuff. I’m considering adding one more audio control 800 watt 4 channel so this way I can change the front stage to be a bit better.
Islandviking
Eyvindur
Norway
Ford Mustang Mach E 2022
Plumber
Do you have/make any schematics for the sub enclosure?
Islandviking
Eyvindur
Norway
Plumber
Did you just disconnect the amp in the back? And when you say you got full range signal from the front tweeters, does that include nav, warning sounds and chimes?
