- Greg
- Apr 20, 2020
- Phoenix
- 2021 Mach-E FE, 2021 Wrangler 4xe High Altitude
- Manager
I think you are right.....the on board LVB is up higher. (too many vehicles.....too little time to remember where all the stuff is....)oh, I see you got the battery junction box. (thanks!)
The LVB is up closer to the windshield, but the LVB jump points are down lower as shown in the diagrams (so just the lower end of the back #2 ground cable, and the + jumper post).
It looks like the BJB is just the regular under the hood fuse box. That kind of makes sense, because there are so many fuses referenced to the BJB now. The only odd thing is that the fuse numbers from these Ford diagrams do not seem to match the fuse numbers in the MME supplementary manual.
So those two 5A fuses probably are the two I found in the fuse box listing of the supplementary manual.
Arrgg, I need to pull those panels again, and see how difficult it is to access those fuse blocks. I wish it was 40 degrees, sunny, but 20F and windy today! (and, some work now, only semi-retired )
I borrowed a Fluke meter and checked those wire again and now I get 6.5 mV so I must have had my meter at home set to the wrong scale. That is unlike me to mistake something like that.....I will check my meter when I get home. I usually break out my PowerProbe because I find that more useful when dealing with automotive electronics but I didn't do that last night.
