Blank/Frozen/Unresponsive screen
EssJayKay
S
Northern New Jersey
Mach-E
Lately I've noticed a few times when starting the car the screen is either blank or frozen. Sometimes it will reboot itself, other times I need to restart the vehicle. Has anyone else experienced this? It is annoying right now, so I wasn't running to schedule a service appointment, but planned to note it when I bring the car in next. Is this due to a software update? Colder weather (in the northeast)?
Luna34
Frank
Los Angeles CA
2023 Mach E Premium
I've had my Mach E for about a month and a half and we started having the same issue a couple of weeks ago. Then it stopped doing it. The wife compared the car to a cell phone. Where it has glitches here and there that end up working themselves out eventually, but can be annoying if they happen consistently.
I think there are software bugs at play, replacing the computer probably won't help. We need Ford to fix their software first.
In the meantime, when the center display freezes right after starting the car, you can either wait it out -- it will restart by itself within 90 seconds, or you can tell it to restart right away.
To tell the computer driving the center display to reset, hold the volume down and next track buttons on the steering wheel for several seconds.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Just in case you don’t know this. You can reboot just the screen by holding volume down and next track for 10 seconds, if that happens when you’re driving.
Ford Motor Company
Official Ford Account
Hello there. Can you please send over a message with your VIN and the name/location of your local Ford dealer? I would like to look into your screen concerns on my end.
OcSteve39
Steven
Wilmington, NC
Mach E GT Performance
Had it yesterday, only the one time.
I went straight for reboot (after restart attempt) and it fixed it.
Lucky luke
Luc
Belgium
Mach-E Select RWD
Sales
I notice the same for +- the last 2 months. I am an European driver, so different sw versions
Deborah
Deborah
CA
Honda van
This happens to me every once in a while. Always in the morning (not that cold, it’s CA, after all). It’s very annoying, but I did not know about the above mentioned reboot technique. Incidentally, I had the dealership check into it the last time I was in for service. They found nothing.
Sildrathus
Richard
23 Mustang Mach E Select
This has been an onging issue for me. I've only had the car for a month. When I left for work it was 50 degrees outside, so I had the heat going. When I got off work it was 85, and that's when the screen was stuck dark, and rebooting sync didn't do a thing. So I drove home in the heat. I took it to the dealer They did a software update, and the issue still occurs. I don't know what to do at this point because it doesn't happen on every boot. But when It does, it's no where near acceptable, as I live in a place where I NEED to be able to control my HVAC system.
Tyler
Tyler
RTP
2024 Mach-E
Brand New 2024 Mach-E < 1,000 miles on it and the Powertrain Control Module (PCM) died. Dealer replaced (had to take the entire dash out) I picked it up and now the screen locks up intermittently and will Ford SNYC will not hold preference settings - drive mode, heat / cool settings etc.. This is my first Ford product and I have been to dealer for service 3 times in 6 weeks - anyone else having these issues with new Mach-E?
Luda07
Christopher
Colorado Springs
Mach E and Explorer Sport
Pilot
Just happened to my Bro’s. Any resolution? He’s got the same exact issue as you with no luck on the soft reset holding the down/over.
Luda07
Christopher
Colorado Springs
Pilot
Update: He unplugged the 12v and reconnected it which fixed the issue. He says he is going to be keeping a 10mm wrench in the frunk from now on :)
