- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
FYI there are two separate Bluetooth connections to the Mach-E on your phone:
"nnnnn MACH E" is for PAAK only (n's are last 5 digits of your VIN)
-This will be active when the car is off and you are nearby it
"Mustang Mach-E" or similar is the SYNC Bluetooth connection for handsfree
-This will only be active when the car is on, and if AA or CarPlay isn't being used
If wireless AA or CarPlay is in use, that runs through a WiFi connection to the phone instead of Bluetooth.
Interference can affect one or more of the above connections and cause disconnects.
Use of other Bluetooth devices or 2.4 GHz on your phone at the same time will reduce PAAK performance because the phone radio is busy serving multiple connections. PAAK needs a fast response (<40 ms) and will refuse late replies. This is why PAAK takes longer if you are listening to music while trying to get in.I know that when Im listening to something on my AirPods on my iPhone and I walk up to my Mach E, it’s takes more than a couple of seconds for the car to recognize the phone. Just try to rule things out via trial and error as most have mentioned.
