Clock won't stay set
eStang
Larry
2021 Mustang Mach-E FE, 2021 Mustang Mach-E GT
software salesperson
Ever since my 2021 First Edition got update 6.1.0 on 09/29/2023 the clock won't stay set. It might just be a coincidence that this started happening when I got that update, but every time I start the car, the clock is set to a new random time. I have set it to the correct time a few times since the 6.1.0 update was applied but it keeps changing to a random time.
Has anyone else had this problem? It's annoying but not so much that I want to waste time with a trip to the dealer unless I know there's a fix available for it.
markboris
Sonora, CA
As Gimme_my_MME mentioned above, check to make sure the Clock is set to Auto update. When I updated both cars to 6.1.0, it changed the clock setting to manual and I had the same issue.
kodiakng
Oregon
2023 Cyber Orange 4X Mach-E
Kmp14
Ken
Chicago
2023 Mach-E Premium AWD Extended
The concept of a clock is a new, complex challenge for Ford :oops:
eStang
eStang
Larry
Thanks! That solved it. However, @Ford Motor Company you should investigate this bug. The clock should stay set across power cycles even if "Auto Time Update" is off.
markboris
Sonora, CA
AtomicInternet
SC
Focus RS, Mach E Premium
I had this issue in my 2017 Focus RS and it was annoying. Happened right after a Sync update and never figured it out. Luckily the next Sync update fixed it. Might want to try a master reset and see if that helps. My sync updates were "unofficial" so I always did a master reset after upgrades and that may have been what actually fixed it.
CopperRobot
Jason
United States
Ford Mach E
Mine has been going into 24 hour mode after some updates. I changed it back to 12 hour and auto update. It went back to 24 hour a couple more times, then eventually stayed at the 12 hour setting. Annoying, mostly because finding the settings takes longer than I like. Not a big deal as others have said, just kind of silly.
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
After an update the clock did not work, so I also set it to Auto and problem solved.
