BSKT Design LED Ponies
GW Shark
Larry
South Carolina
2021 Premium ER AWD Star White, 2014 Prius V
Scuba Instructor
Ah! That’s a shame. Do you think they had you?
No - just a $10 reservation to get the lowest introductory pricing. Production was disrupted due to the earthquake in China earlier this year. Mark has indicated he may be able to get additional information.
Teslaeata
Nottingham, England, UK
Good luck?
markboris
Sonora, CA
Good luck?
Luck has nothing to do with it. I will get an answer tomorrow (It's night time right now in China) and if this isn't happing, Larry will get his deposit back pronto.
markboris
Sonora, CA
Thank you!
Ok, 300 of those grilles have been produced and should be in stock in the next two weeks. However, there is a change in the colors in that only the OEM GT color grille was made. They will not be making various different colors as was first mentioned on the product page in the store. So, if you ordered one in the OEM GT color, you will be good to go but if you want it in a different color and put the $10 deposit down, you will get your money back unless of course you want to change to the OEM GT color. You will be notified as soon as the item is in stock to purchase it.
GW Shark
Larry
South Carolina
Scuba Instructor
Thanks! I appreciate the effort and information.
markboris
Sonora, CA
One more thing, the price of that grille is $499 but anyone that paid the deposit of $10 will get it for the introductory price of $299.
GW Shark
Larry
South Carolina
Scuba Instructor
Yep!!! Also, FYI, shipping (USA) to me is listed as $99.
markboris
Sonora, CA
Don't know anything about that. I only take care of the shipping of illuminated ponies and GT emblems.
AllTheThings55
Mesa, AZ
2023 Mach E Select w/AWD
Professional Services (IT)
I received my replacement connector (low) late last week and got it installed over the weekend using the yellow wires. The passenger side marker light is back and my pony looks as good as ever!
markboris
Sonora, CA
To everyone that has contacted me either here on this thread or privately, I have shipped out all the updated front and rear connectors for those that had issues with theirs. If anyone still needs one please DM me your info and I will get one out to you.
Mach e Aankh
NJ
Mach e Ex RWD BLK
Self
Hi just received it and was wondering what's the difference between the one I received in July. Will it light up bottom half as top does
Thanks
markboris
Sonora, CA
Thanks
You received an updated connector which allows for the pony to light up two different ways on SOME models, not all. Connecting the two yellow wires will light up pony only when headlights are on while connecting the red wires will light up the pony anytime the running lights are on. Again, this only will work on some models.
What do you mean will it light up the bottom half same as the top half? Are you saying your pony does not have even lighting across the entire emblem? If that is the case, that is a pony issue and I will send you a new one.
markboris
Sonora, CA
I recently installed the front pony light on mach e premium with high wiring so that the pony light stays on all the time...it looks like when i plug the red wire "all the time" wire in it does not work at all but only when the yellow wire is connected. Having waiting for a response just seeing if there was an issue with this anyone else has. Currently only works whn the headlights are on and want it on when the drl is on
There is no issue with your connector. Various years and models work differently. '21-'23 will work with both red and yellow connections doing what they are supposed to do. '24 and up only work with the yellow connector and only comes on with the headlights. Your connector should have come with a very long red wire. If you want to have the pony come on all the time the DRL's are on, you need to run that wire to the inside and connect an ignition wire with a fuse tap at the BCM. There is also a wired you can tap into in the Frunk compartment but it is not an ignition but will basically do the same thing. I can explain more about that if you want.
noah7
Noah
cleveland
2024 Mach E Premium 4X
data analyst
Oh good to know! I was wondering why it was not working! Yes i do have a red wire if you can explain where to hook that up to that would be great!
