BSKT Design LED Ponies
DMoore
Darren
Northern Ireland
Mach e GT
Can you get a light up pony for a 24 GT. Here in the UK they’re not supplied lit up like the US cars
Thanks will do. Are they easy enough to fit to a GT
I would not be able to tell you that. Your GT is not like our GT. I would assume your pony on the front is the same as the one on our non-GT's. Here, our OEM GT ponies are completely different and mount differently than the non-GT pony. Bruce has sold many of these in Europe, maybe someone there has installed one on a GT there.
New2EV
Palm Bay Florida
Charger, Explorer, Chevelle, Mach E
Here is a photo of the correctly wired connector. You can see the white wire from the black box is going to the wire on the end of the connector instead of the middle wire like it was before.
Can you send me a corrected harness? BTW, what is the short wire on the RH side? Does it have voltage? Do we need to do anything with it?
I will send you a harness today. That short wire was previously used in another application. Just needs to be taped up (like it was).
Hi Mark, did Bruce happen to identify the issue with the low configuration setup?
I am sending you an updated Low harness version that I believe will work. Going off of what I did on the High harnesses, did the same on the Low. You get to try it out. ?
And it's official, back pony had no issues lighting up and I had no issues running the wires to the break connector.
Very nice. So you had no issues with the front or the rear ponies! That is how it should be. Glad to see you are enjoying them!
I fixed my front today, works fine now. If you need to mark me off a list of potentials later, just message me.
My rear isnt working correctly though; it turns off the inside bottom passenger side tailight; no tail light, no brake light, no amber flashing. I might need a rear harness replaced :/ I'd post the video but my plate is in the picture. If its needed ill post it later. I did message Bruce so Ill see what he says.
Thanks for all the hard work on this Mark, your contributions do not go unnoticed!
I don't understand why you are having a problem with your rear pony. This is the first I have heard of this issue. I have personally installed 3 rear ponies recently and all are working great. There could be a problem with the pony or connector and I can send you a replacement.
Mr.GVAK
Ash
2022 Mustang Mach-E Select - Star White
While I wait to test the new Low Harness from the front pony, I wanted to share some feedback on the rear pony. The adhesive used to attach the emblem to the base doesn’t seem strong enough—one end has already come loose. I’m not sure if this is due to the hot weather or general durability, but I’m unsure how well it will hold over time. That said, the pony functions perfectly and the overall build quality is better when compared to the factory version.
Ash, I am going to send you a new rear pony. Maybe yours was warped or something. It should lay flat on the liftgate. I have not had issues with the ones I have installed.
Mr.GVAK
Ash
Great, thanks Mark. Yeah, mine was probably just a one-off issue.
The Low Harness is arriving on Saturday—really looking forward to testing it out. My MME feels kind of naked without the frunk! ?
Mr. Toejam
Mr. Toejam
Spence
So. Cal.
Retired - Dir of MFG Eng
Did you connect the control wire for the reverse light? If you did, disconnect it first and see if this resolves your issue. Maybe it s connected to the wrong wire.
My harness is from early in the year and it is fine and it looks like the recent ones are working for others.
