Charge Rate on the mach-e
mac123
Mach-e GT, 05Lexus GX470, Model Y,R1S (order)
Is there a way to see the charge rate on the mach-e. I just took delivery yesterday and plugged in my car on the 14-50 50 A outlet at home. I've checked both the car and the mobile app and have not been able to determine the rate of charge. Does anyone know where i should look?
In FordPass, you can look at the session while it's charging (click on the blue bar). However, I find it usually provides little information.
In the vehicle, you can power and see when it will be complete, and do the math.
The charger that comes with the vehicle, runs at 32amps, which means you're delivering roughly 29 - 30 amps to the car. That gives you about 20 miles per hour of charge.
timbop
You can also look at the charging percentage and charging time in FordPass (either in battery logs after the fact or using the procedure @RickMachE said) and do the math yourself. For example, if you have an extended range battery multiply 88 by the percentage charge to get kwh, and then divide that by the time in hours to get the rate (kw).
