Charging Help - 240v
timbop
Actually, that picture is a 10-30, which is an older 3-prong dryer outlet.
Right, all he needed to do was replace the $10 outlet. But, it looks like he's just going to do it right and replace the whole circuit
timbop
I have a picture of the Mach E 240v outlet.
yes, that is a 14-50 plug. He was saying your existing 30A outlet is not a 14-30 but is actually a 10-30
Swirls78
Swirls78
Joseph
CA
Ford Flex
Teacher
Yes, I understand. Sorry for the confusion. I was told I could use the 30amp with a 14-50 plug. After watching a few videos and looking through the Mach E forum, that might not be the best option.
MY21 J1 Premium RWD SR
Carsinmyblood
Mitch
Western NC
Self employed
Oh, one more tip:
Be sure to mount the charger at least 75" higher than the receptacle on the car to help the formbates flow more freely past the marcel vanes in the stater.
And remember to place the step ladder on a level, firm surface to avoid personal injury.
Swirls78
Swirls78
Joseph
CA
Ford Flex
Teacher
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
Awesome. Thank you! Am I missing something with the attached photo. It says 240v 30amp with a NEMA 14-50 wall outlet.
As others have pointed out, the Ford Mobile Charger comes with a NEMA 14-50 plug, so it needs to go into a NEMA 14-50 outlet. A NEMA 14-50 outlet needs to have wire rated for 50 A. That doesn't mean that what plugs into it needs to pull the max current. The Ford Mobile Charger only pulls 32 A. So you need a NEMA 14-50 outlet to physically plug it in, but it will only pull 32 A.
You cannot use an adapter to plug it into a dryer outlet because that's only rated to 30 A, so plugging it in with a physical adapter will result in the Ford Mobile Charger pulling 32 A and tripping the breaker. You can use the dryer outlet, but then you need a different EVSE that only pulls 24 A (80% of max rating of 30 A).
Swirls78
Swirls78
Joseph
CA
Ford Flex
Teacher
Okay. I understand. Thanks everyone.
timbop
Actually, code allows you to put a NEMA 14-50 on a 40A circuit (40A breaker and wire rated for 40A such as #8-3 romex). 30A is not allowed for a 14-50, however.
CHeil402
King of Prussia, PA
Electrical Engineer
Only on a technicality because there are no 40 A receptacles and certainly not good practice, so I would never recommend it. If you're installing an outlet rated for 50 A it should be supplied with 50 A wire. What happens if someone who's expecting it to be 50 A uses it as such?
timbop
It is allowed by electrical code, and actually fairly common. Label the outlet as I did.
No, a bad option. It'll blow your breaker every time you charge. You'll be putting a 32A load on a 30A circuit.
Blackbluff
Gerry
Bartlett, TN
2021 Mustang Mach E
Oh, one more tip:
Me thinks there be something else in your blood.
