Charging issue
MME Farmer
Mn
2026 nautilus, 2021 GTPE, 2026 F350, 2017 F150, 05 trailb, 04 PT, 94 Dod 2500
Farmer
I was all excited a couple days ago as I was to receive the long awaited BC 1.3 update. Since I have it scheduled for updates at 1:00 am each night it looked like it was going to do it the night before last. It was plugged in and should have charged from around 60% to 90%. That night it only added maybe 5% which is not normal. So last night I made sure that it was charging in the time period I have set and it was at 32A, 7.4 kw. It had showed that it wouldn't reach 90% till 10:30 tonight which would be wrong. I noticed that it still showed a departure time that I had set, I shut that off and it showed that it would be charged by 6:30 this morning which would be right. When I got up it was still charging but had only added 10% and the departure time was turned back on and the update had not happened. Up until receiving this potential update everything has been working normal. Any thoughts would be appreciated. Thank you
The update is still pending.
Try to apply it manually.
Delete departure time in vehicle.
MME Farmer
Mn
Farmer
Thank you sir! I did what you said and it now says the update was successful and charging is back to normal. Anxious to see if 1.3 is much better than 1.0 which has worked fine for me, the lane change feature should be nice. Thanks again
