Charging more than 80% regularly?
OON7
Evan
New: 24 GT w/ perf. upgrade Vapor Blue // Old: 22 GTPE DMG // 21 Select CG
I charge to 95% at work for free and to 70% at home. Battery health is 99.5% after 16.5k miles.
Gyrfalcon08
MD
Mach E RWD ER Premium
Since the long term storage recommendation is 50%. Based on my average commute I charge daily to 70% so that when I get home the car sits at around 50% for the max amount of time until charging starts at midnight.
johndenver
john
Denver, CO
2023 Ford Mach E Premium, 2020 Ford Raptor
I was charing to 90%, but with a long commute it got annoying to charge so offten. I just go to 100% every time now. Not worried about the battery, many people do this and after 3 years or so have no degradation.
--John
sparkout
Cliff
2021 Mach E 4X Premium
Hello everyone. Just got my 2023 space white Mach E GT AWD. I love it!! Just wondering if anybody is charging it more than 80% on the regular. Thanks.
I charge from 20 to 95% every 10 days
Lalji
Canada
2022 Mustang Mach E GT
I drive the car for a few kilometers at a time, so mine is always at 60%. I believe that is the safest place for the car battery to be. The lowest I go is about 30%.
I got the car in January and I'm at 1,700 KM. That is slightly over 1,000 miles in over 6 months.
Eagertrader
Norberto
Mustang Mach e GT
Realtor
Got the same model and color that you have, an MME-GT in Space White except 2021 probably a second build. I always charge to 100% and have not seen any degradation thus far. In fact, this year on some hot days I've got as much as 305 miles of charge. I'm near DC.
movieman
Mustang, Fusion, Mach-e (on order)
Quick question: If the car is set to charge to 80 or 90% at your home location, and you want to charge to 100% before a trip, then do you have to manually go into the charge settings to change them each time you want to charge to 100% or go back to a lower charge? My understanding also is that changing those settings in the App is not reliable either. Thx
In the ford pass app under the charging settings there is a button : 'charge to 100%'. You can tap that and you do't have to change your charging presets. I hit it last week by mistake and the battery charged to 100%
Chitown
Chicago, IL
2023 GT Performance
Software
You've gotten a lot of good replies - but know this:
Percentage is part/total. It's meaningless unless you know what either the part or the total is. 5% of 100,000 (5000) is much bigger than 50% of 100 (50).
In this case, Ford "saves" the top 10% of the battery's physical capacity, so assuming a 91kW battery, that means you never see the "top" 10% = 9.1kW. So your usable capacity is 91kW-9.1kW = 81.9kW. So, at 90% indicated on the GOM (Guess-O-Meter), you will really be at 81% (81.9kw *.9/91kW) of physical.
So charging to 90% indicated is really 81% actual.
zvez
chris
ga
I'm not sure the buffer should be considered in the charge percentage. I mean clearly ford is being extra cautious with a good sized buffer built in , but they still recommend for average use unless you need the mileage to charge to 90% ac charging.
Chitown
Chicago, IL
2023 GT Performance
Software
I'm okay with it personally - because in a few years they can "unlock" that 9.1kW and viola - you get "extra" range.
Teslaeata
Nottingham, England, UK
60,000 miles in 2 years so have to charge to 100% twice to three times per week sometimes and battery seems to be holding up.
I only charge to 100% when I know I’m out on road following morning and if not out on road and really low charge the night before I go to 90%. C40% of my charging is on the road at public charge points and probably only half of those occasions do I go to 80%.
jeffdawgfan
Jeff
Georgia, USA
We have had our Mach E two years and almost 30K miles. Charge to 100% every single time.....about twice a week. No degradation noted in range. Still getting over 300 miles on GOM after charge. AWD ER Premium.
Steady Eddie
Edward
Bay Area
2022 Mach E Premium
I came across this on YouTube suggesting keeping charge between 65%-75% to maximize battery life.
the article referred to in the video is https://batteryuniversity.com/article/bu-808-how-to-prolong-lithium-based-batteries. For me charging to 70% has been more than adequate — except for when we prepare for a trip.
Space_Pony
Indiana
2023 Premium Mach-E awdX
That video is based on cell phone batteries and I believe EV batteries would need different testing data since there are many differences between cell phone batteries and BEV batteries.
