Checking battery capacity - 80.9 kW? WTF?
Mach1E
I haven't looked at those numbers when SOC was 100%, buy did extrapolate while SOC was in the 60%-70% range - it came to 79kWh when HVB temperature was reportedly 11C (min 9C, max 14C) and 89kWh at 25C (18C - 27C).
I wonder if people would be happier or angrier if the charge % was more truthful.
Like if you can only charge to 70% in the cold, it actually SAYS 70% on the dash (instead of 100%).
Or if they used the gray bars of sadness like they do on the power meter for the GT.
wings2063
Ron
Dallas
EV6 GT-Line /Mache Premium 4x
2021 Mach E Premium, AWD, Extended Range
I charged to 100% today (Jan 19, 2022)
Checked using OBDLink software, parameter EV Battery Energy to Empty = 80.9 kW, WTF? Maybe that's partially responsible for poor range (other than lower temps)? At 100% this time, GOM said 171 miles.
I have the same reading from my testing and that was when my 88Kw battery was at 23C. I am wondering if the OBD app is reading the info from the car properly. I have used "car scanner" and "Ford HVB" apps, both report 79.x to empty.
Accord07
Earth
Yugo
I think some would be upset either way :)
It really comes down to expectations. This is my first EV but for the last 30 years I have never had a battery whose performance did not degrade in cold weather, regardless of the chemistry/type of batteries. The worst offenders were the 2CR5 lithium batteries found in many cameras from the late 80s through the 90s. In cold winter months I sometimes spent more on batteries than on film.
The fact that multiple people have identical readings, and likely not identical battery temperatures, points to inaccuracy in the apps.
JeffGo
JeffGo
Washington, USA
2024 MME GT in Eruption Green
I usually use FORScan Lite but since the latest iOS update, it won't connect. I don't think it's the software.
