Corvette Jack Pads installed
gryphon
2023 GTPE (Declined Delivery); 2023 BMW iX M60
@kennethjk and @markboris Thank you both, the additional information and photos are very helpful. It is great to see two slightly different approaches using the same materials.
They're not a perfect match with Grabber Blue but they do nicely. I used Gorilla Tape in addition to the single screw and backing plate.
Ford Mustang Mach-E Corvette Jack Pads installed ?hash=c3f02d70e513930c0a4d0cd652ed9d57
Ford Mustang Mach-E Corvette Jack Pads installed IMG_6190
Ford Mustang Mach-E Corvette Jack Pads installed IMG_6189
Lynsey
San Diego, CA
2022 Mustang Mach E GT - Star White
I did exactly how you did it in the video. No problems. They aren't going anywhere. Don't feel like it needs 3m tape etc. I used the same marker too. Love that thing. Marked my house numbers on my trash cans too! Thanks. Debating on the stickers...seems like the red pucks should be enough with the highlighted arrows.
Ford Mustang Mach-E Corvette Jack Pads installed 20221108_085812
DadzBoyz
Oldsmar, FL
22 Mustang Mach-E GTPE (ordered), 20 Mazda CX-5
Software Systems Integrator
Great video Rob. I went with black pads and lift stickers because I didn't want them to be noticeable at all from looking at the sides (only while looking under the car). I'm the only one that works on my car (until I get the HVBJB replaced) but I think colored pads are definitely more noticeable than black ones even with stickers and for owners that are always having their cars worked on (tire rotations, changing to winter tires, etc.) that is the way to go.
Love the "Lift Here" sticker. Where did you get that?
I see Ken beat me to it again. ?
Yes Amazon.
And I didn’t upload photos of my black pucks because Ken did a great job taking photos of his.
Curious about galvanic corrosion impacts with these in areas with road salt. The aluminum may act as a sacrificial anode for the pack and end up welding itself to it with corrosion. They may end up looking pretty crusty after a year of salt. Salt water may also stay trapped between the puck and the battery case, causing it to rust out under the puck.
kennethjk
Ken
MME Prem. EB 4WD, X3, IX50
Yes Amazon.
Mark:
Benefits of being retired and my only job is to read this forum and see grandkids.
I take care of the easy stuff and leave the more complicated things to you and others.
I can see this possibly being a problem with some people but I wouldn’t have that issue as it doesn’t snow around where I live much and when it does they don’t put anything on the roads since it’s rare.
Mark:
Ken, I’m just as retired as you are and like helping out on this forum as much as I can but I also travel quite a bit. Actually on a plane right now to Italy for a few days so won’t be on here as much for while.
kennethjk
Ken
@markboris enjoy your trip
@Mach-Lee , good point about corrosion but the puck doesn’t touch the battery case.
It touches just the lift point metal, I would assume that’s a bit better but aren’t both corrosion protected anyway. . In any case moving my car to florida for the winter and if in the snow I guess I will have to flush it out from time to time.
DadzBoyz
Oldsmar, FL
Interesting thought. Maybe cut a circular rubber gasket, of sorts, to place between the puck and the car...
Ford Mustang Mach-E Corvette Jack Pads installed 1668028836122
kennethjk
Ken
Good idea but mine are already on the car so I thought maybe some type of caulking , silicone around the edge of the puck might suffice
krazieboy
US
Mustang
Ive done mines quite a while back. Used automotive goop for the puck, and blue loctite on screw. been about 7-8 months now with no issues. Dealership jacked the car up from there when i did my rotation recently.
Ford Mustang Mach-E Corvette Jack Pads installed 1668122478163
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Took a few pictures.
from passenger side I was 10 ft away on my knees and from the drivers side I was 6 feet away Also on my knees.
I also took a picture of 2 of the pucks, the driver Side, rear and front
hope this helps
I opted for the blue ones too. Will install them soon...
JohnFoxeSheets
San Francisco
johnfoxesheets.com
I installed mine this evening. Of course I didn't see Lee's post about galvanic corrosion until after I used red Loctite on the screws. (I figured, I'm never going to want to remove these suckers...?) Luckily I don't live in snow/ice country!
Ford Mustang Mach-E Corvette Jack Pads installed IMG_1384
