Please post your vehicle weight information!
SpaceEVDriver
Planetary Science
I've been trying to find specs published by Ford, but have failed. So, I'm asking for help.
I'd like to collect information from your safety compliance certification labels. Would any of you who have received your vehicles be willing to post the following information? It should be available on the front driver's side door stickers. Various options will change the maximum cargo limits, so please post even if someone else has posted your trim+drive+battery combination.
  • Year
  • Trim (Select, Premium, CA Rt. 1, First Edition, GT, GTPE)
  • Drive (AWD, RWD)
  • Battery (Extended, Standard)
  • GVWR
  • GAWR (Front)
  • GAWR (Rear)
  • Maximum combined weight of occupants and cargo
Thanks!
Update:
Here is a table from the data you all shared! Thanks!!!
YearTrimDriveBatteryGVWRGAWR (Front)GAWR (Rear)Max CargoCurb WeightRange (miles)
2021GT PEAWDExtended5980280532609125068270
2021PremiumRWDStandard5340242030409054435230
2021PremiumAWDExtended5800266032259104890270
2021PremiumAWDStandard5500257030208834435211
2021SelectRWDStandard5340242030409794394230
2021PremiumAWDStandard5500257030208834617211
2021PremiumRWDExtended5560248031858674693300
2021SelectAWDStandard5500257030209324568211
2021SelectRWDStandard5340242030409794361230
2022CA Route 1AWDExtended5760266032559684792312
phidauex
Sam
Colorado
Renewable Energy Engineer
SpaceEVDriver
SpaceEVDriver
Planetary Science
I have several options listed in one of the data tables in this post about wheel specs. I'm still missing a few as well, I'll update as people post options I don't have (still need Premium RWD ER, Selects, and GTs).
https://www.macheforum.com/site/thr...fset-center-bore-load-rating-gvwr-table.3037/
I saw those, thank you. I was hoping not to derail your thread; I didn't want to post in there asking for this information. I'll copy them into my spreadsheet, which I'll post when it has more data.
phidauex
Sam
Colorado
Excellent, round 'em up and I'll update when convenient!
ARK
Los Angeles
'21 Premium SR AWD
  • Year
  • Drive (AWD, RWD)
  • GVWR
  • GAWR (Front)
  • GAWR (Rear)
Thanks!
2021
Premium
AWD
Standard
GVWR 5,500 lbs
GAWR (Front) 2,570 lbs
GAWR (Rear) 3,020 lbs
Max Weight 883 lbs
The only possible option on this vehicle was the interior protection package, which I doubt would have changed any of the numbers. I did get this package.
Ford Mustang Mach-E Please post your vehicle weight information! 6C6F4F82-FB70-4708-9AE0-43AD24BE6C5D
Ford Mustang Mach-E Please post your vehicle weight information! 247F7A45-EC1F-411E-B7BA-05038AE8A61B
SpaceEVDriver
SpaceEVDriver
Planetary Science
Premium
AWD
Standard
GVWR 5,500 lbs
Max Weight 883 lbs
Excellent! Thank you!
SpaceEVDriver
SpaceEVDriver
Planetary Science
  • 2021
  • Premium
  • RWD
  • Battery: Standard
  • 2422 kg, 5340 lb
  • 1098 kg, 2420 lb GAWR (Front)
  • 1379 kg, 3040 lb GAWR (Rear)
  • 410 kg, 905 lb Maximum combined weight of occupants and cargo
Thank you!
ohmslaw
Joseph
Connecticut
Toyota Highlander, Toyota Rav-4, Mach-e (on order)
Here is mine
  • 2021
  • Premium
  • AWD
  • Extended
  • 5800lb total
  • 2660lb front
  • 3225lb rear
  • 918lb max load
SpaceEVDriver
SpaceEVDriver
Planetary Science
Premium 4x Extensed range:
Max vehicle load: 918lbs
Gvwr: 5800lbs
Gvwr front: 2660lbs
Gvwr rear: 3225lbs
  • 2021
  • Premium
  • AWD
  • Extended
  • 5800lb total
  • 2660lb front
  • 3225lb rear
  • 918lb max load
Thank you!
ohmslaw
Joseph
Connecticut
Just wanted to bump this with some reasoning behind acquiring this data (taken from a thread I started and want deleted; don’t want to request data in two places)
I went to look at parts for the Mach-e to see if any suppliers have figured out aftermarket equivalent dampers and discovered the following
There are different part numbers for AWD and RWD for the front suspension.
There are different part numbers based on battery size for the rear suspension.
Having all this data will potentially allow a better understanding of what the vehicle load impact would be switching out the rear dampers. Furthermore if spring rates and damping ratios are ever obtained it would allow some level of modeling that may find a form/fit replacement damper that would change the dynamics of the vehicle.
SpaceEVDriver
SpaceEVDriver
Planetary Science
Just received notification that my 2022 CA Rt. One is ready to purchase and the vehicle has arrived at the dealer! Will post the weight information here as soon as we have the vehicle (probably tomorrow or the next day).
(Using this to bump the thread)
SpaceEVDriver
SpaceEVDriver
Planetary Science
Also, I updated the thread title to be more of a request than a question.
phidauex
Sam
Colorado
Just received notification that my 2022 CA Rt. One is ready to do the purchase software and the vehicle has arrived at the dealer! Will post the weight information here as soon as we have the vehicle (probably tomorrow or the next day).
Yeehaw, glad to hear you are finally getting yours!
SpaceEVDriver
SpaceEVDriver
Planetary Science
Thanks @ohmslaw!
I'm looking for similar reasons and also because I'm a data nerd.
