YeOldeTraveller
Clark
Ann Arbor, MI, USA
2024 MME Rally
Monday, I did a short trip to test DCFC for my new MME Rally. (I know this is old hat for most here, but it might be interesting to some.)
First test was a local Tesla Supercharger with Magic Dock. I had just seen a YT video using a Magic Dock without needing the Tesla app. This test was to see what it would take, and if this actually worked. I was able to park in the spot just right of the rightmost spot. I needed to pull closer after checking cable length. Held the button on the plug for a bit over 2 seconds, and the adapter audibly unlocked. Pulled the adapter out and plugged in. ~20 seconds later, charging started. I could see the rate in the FordPass app. The only way I found to stop the charge was the button next to the charge port.
Second stop was Electrify America. No issues. Slower to start than the Tesla, but no additional effort needed. Same ability to track in the FordPass app. I could have stopped the charge from the dispenser, but I used the charge port button again.
Each of these sessions was followed up with an email from Ford with the cost of the session.
Next, I took a longer run down to a Pilot with an EVgo charger. I used this session to complete the setup of Autocharge+. This was reported by EVgo, as one would expect.
Final test was at a ChargePoint. This was a slower charger, but I wanted to see how it would work. There was an issue with the latch on the CCS cable, but it staying plugged in, and I was able to complete a charge. I activated this with the FordPass app without issue. The broken latch was reported previously on PlugShare, and I added my own note that it was still broken.
Previously, I had installed the apps for a few CPOs I expect to encounter in my next road trip. The effort in getting them configured ranged from almost no effort, to extremely painful. I have to wonder where they found programmers for a couple of these. I have only actually tested EVgo, so, I will need to double check a couple, just in case.
You can stop charging from the center screen also.
SpeedRacer72
2018 Mustang, 2024 Tesla Model Y Performance
So is my take away that a 2024 Mach-E can DCFC on the same networks as a 2021-2023 Mach-E??
Take it easy, he is new here. You don't have to let him know right out of the gate that half the people on this forum are jackasses
Winter is right around the corner and when he starts asking why his range is so low, then he will find out just how many jackasses there are
Which half am I in?
Jackass half or Smartass half?
? :D ?
Why limit oneself? How about schmatass? ??
We of the canine persuasion like to sniff ass ??
YeOldeTraveller
YeOldeTraveller
Clark
Ann Arbor, MI, USA
2024 MME Rally
I'm sure you are correct, but I have not done any of those things, and there is a difference between, it can and this instance of driver and vehicle will. I would much rather find out I have a problem with payment or settings when I am still in range of home, than in the middle of the Upper Peninsula.
hybrid2bev
2026 Rally
You are correct this is a great idea for new EV drivers. If you've never done a DCFC then try to do your first one close to home.
n2585722
Danny
Cedar Park, Tx
2024 Mach E GT
I did the same and went to a local supercharger and charged a while and disconnected and went to EA and charged for a while. All went ok for me but I had the car for 6 months before trying DCFC out.
zvez
chris
ga
Which half am I in?
? :D ?
post #3 above, I'd say you could be "leaning" in the jackass group ;)
zvez
chris
ga
Under Charging as I recall.
The dc charge unlock button is on the "settings screen upper right between liftgate and frunk(?) is that the one you're talking about?
