Dead while driving.
tfitzgex
tfitzgex
tom
Portland Oregon
2021 Mustang Mach-E Premium extended range AWD
These are the notes, interesting that they redid 21p22
Also, my frunk button is missing :(
Ford Multi-Point Vehicle Inspection. Perform a thorough inspection of
fluids, wipers, battery, tires, brakes, safety systems, and
components.
99PX Ford Multi-Point Vehicle Inspection. Perform
a thorough inspection of fluids, wipers,
components.
1816 C 0.00 0.00
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE A: 0.00
B PERFORM RECALL 21G01
21G01E RECALL 21G01
1816 W (N/C)
1 NK4Z*10C666*B CONNECTOR (N/C)
CORE CHARGE W (N/C)
-1 NK4Z*10C666*B CORE RETURN (N/C)
MT21G01C MTIME
1816 W (N/C)
MT21G01B MTIME
1816 W (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE B: 0.00
18666 Customer requested 21G01 be performed to enable blue cruise.
Updated modules in order from the instruction sheet. made it to step 19
without issue. Found 21P22 has not been performed so I updated the
OBCC, DCME, DCMF, DCMG, DCMH, RFA, and BCM. The BCM Update Failed twice
without an error code before finally programming and removing itself
from the available updates list on FDRS. Proceeded to step 20, there
was no update from the GWM, moved on to step 21 to update the APIM.
Updated APIM, and now there is an update for GWM. Updated GWM and then
the APIM again before finally being able to finish the program. Test
drove and bluecruise worked correctly. Requesting additional time to
program modules additional times outside of the program so that I would
be able to finish the program in the correct order.
C** CUSTOMER REPORTS VEHICLE DIED WHILE DRIVING AND NOW NO CRANK NO
START
CAUSE: .
12651D BODY / CHASSIS / ELECTRICAL (BCE) - TEST
1816 W (N/C)
MT212245 MT212245
1816 W (N/C)
12651D54 JUNCTION BOX - HIGH VOLTAGE BATTERY
(BEC) - REPLACE (10C666) - L
1132 W (N/C)
MT MTIME
1132 W (N/C)
FC: PART#: COUNT:
CLAIM TYPE:
AUTH CODE:
1816
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE C: 0.00
18666 7.00
Customer towed in car that would not start. Was able to manually
pop the hood and get the doors open by jump starting the battery,
vehicle would still not start. Connected FDRS and pulled codes. Had
multiple codes that cleared. One stayed P1A10 Which had a TSB out for
it. .Performed PCM software update as per TSB 21-2245. Vehicle now
starts and runs as it should, all codes cleared. FSE instructed us not
to release the vehicle to the customer while we order a part under his
direction.
Replaced BEC (HV junction box) as per FSE. mtime needed for no
coolant bleeding labor op and for road test.
D** CUSTOMER REPORTS RIGHT SIDE STEERING WHEEL SWITCHES ARE
DELAMINATING
MT9C888 STEERING WHEEL SWITCHES
1816 W (N/C)
1 LJ8Z*9C888*C SWITCH ASY - CONTROL
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE D: 0.00
18666 customer states that the sterring wheel control switches are
delaminating. Removed and replaced both right and left hand switches
upon further inspection they were both delaminating. Mtime requested
due to lack of labor codes.
E** PERFORM PROGRAM 21P22
MT21P22B CUSTOMER STATES POWER TRAIN MAL
1816 W (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE E: 0.00
18666 Performed open program 21P22 in order to finish program
21P22. Updated OBCC, DCME, DCMF, DCMG, DCMH, ABS, RFA and BCM all
modules completed successfully in just over an hour with the OBCC
having a second update after finishing the list.
F** CUSTOMER REPORTS AIR BAG LIGHT IS ON WHILE DRIVING
01CFL RECOMMENDED MAINT
999 C 0.00 0.00
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE F: 0.00
G** Tire Rotation Service
CAUSE: Performed tire rotation
46CFL04 Tire Rotation Service
1667 C 0.00 0.00
SUBL RENTAL CAR PER FORD PO#125621
W (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE G: 0.00
18666 PERFORMED TIRE ROTATION, INSPECTED AIR PRESSURES.
H** RENTAL CAR PER FORD
RENTAL RENTAL
999 W (N/C)
BadgerGreg
North Carolina
I see they replaced your HVBJB. That's reassuring. When I read your previous update it appeared they only cleared the error codes and updated the software, but the service record showed that they went beyond that.
Welcome to the club. Here's your membership card: you can fill out the name on your own...make sure you laminate it :)
Ford Mustang Mach-E Dead while driving. HVBJB Clu
santa fe,nm
www.envirokarma.org
Solar Sales/install
hhhmmmm, it might be a great thread to add 'HVBJB club' for those that have had HVBJB replaced to gather and post dates and conditions of failure as well as time to repair so that Ford can see everybody in one place rather than sprinkled around in various threads.
I'm still wondering when we'll spot the common thread CAUSING the failures.
Seems to me that the failures are most likely the contactors, but we don't have access to the autopsy data. The most logical CAUSE is opening under load, and the mostly likely time that might not be handled right is when terminating a DCFC session.
pure conjecture, but seems to be fitting the facts.... the failures seem to be higher with people that have used DCFC more often than people who seldom, or never use DCFC. I would love to know if any of the people that have had HVBJB replaced never used DCFC, or sometimes, or many times.
chrisGT
Northern California
2021 Ford Mach-e GT
I know of at least one owner who had a fried HVBJB in an almost new MME without ever using DCFC. So I believe it is caused by something else.
Logal727
C
They do a DCFC test before they send it out for delivery at the factory, so wouldn’t say never.
BadgerGreg
North Carolina
I've thought about this too. My two failures both came after a period of heavier DCFC use. The first a few hours after a couple of failed charging attempts at a ChargePoint DCFC (at that ChargePoint I eventually got a DCFC session going after they reset the station). The second failure was 3 DAYS after my 2,000 mile road trip where I had obviously been relying more heavily on DCFC. Even then, the replacement HVBJB failed quickly (while still at the dealership) after zero DCFC sessions.
Both failures were under different circumstances, and the time proximity to DCFC may just be coincidental. The fact that the replacement HVBJB failed suggests that maybe the part is just not very reliable under any type of use.
BadgerGreg
North Carolina
Me too. When they replaced my HVBJB, the replacement unit failed almost immediately (with no DCFC sessions). Fortunately this happened while my car was still at the dealership's service center.
chaifarm
SD
MME
I did a DCFC charge on my MME (car had about 1400 miles on odometer) at an EVGo station. Wtihin a week my car had bricked. It has been at a dealership awaiting a new HVBJB, connectors, battery, etc., for nearly 3 weeks. Have no idea if there is any correlation between the DCFC and the subsequent total system failure.
scoopman
Bay Area
Hey club members!!
I just want to help stir the pot of speculation by saying that I was initiated into the HVBJB club only about 1 week or so after I shot my 0-100% DCFC charging test. That definitely exercised the part that failed nearly a week later. Remember, feel free to post all your stories, but also please report this to NHTSA here: https://www.nhtsa.gov/report-a-safety-problem#index
AllenXS
Allen
Richmond, BC, Canada
Premium Blue ER AWD
I drive down to Seattle for the driver electric event and used the ea free electricity at a dcfc charger. When I got home the next night (no further chatting in between) I had charging issues overnight. After work I threw it on the charger and got the pull over safely, thankfully at home.
No such thing as a free charge?. HVBJB install started today after two weeks. Hopefully they update everything next week so 2 1/2 weeks minimum.
I felt like it was the dcfc charger that threw it out so interesting to see the comments above.
tfitzgex
tfitzgex
tom
Portland Oregon
The problem is I have no other way to really charge other than dcfc. I live in a townhouse. No 220v. The fleets of these cars that have been tasked with being police cars or taxis will need to fast charge reliably.
Jimbo
Jimbo
US
Premium 4X
Tangent, but
These are the notes
DELAMINATING
1816 W (N/C)
So delaminating switches are warrantyable? Sweet (mine are still good, but it's only been a few months)
santa fe,nm
www.envirokarma.org
Solar Sales/install
do you have assigned parking areas? I wonder if the Association would be open to adding solar carports with L2 chargers as an 'upgrade' , or monthly fee, or Leased equipment ?
Most Fleets won't NEED to have DCFC.... I'd be amazed if muni or private companies would spring for DCFC stations as they are VERY expensive.... much more likely to have a row of L2 chargers and give employees incentives to add chargers at homes and parking garages where the vehicles sit when off-duty.
Rental agencies however might be another story where they could have a car come back empty, and the need to clean and re-charge asap to send it back out.
tfitzgex
tfitzgex
tom
Portland Oregon
Tangent, but
Anything can be a warranty issue if you know the right words to say to the dealer :)
tfitzgex
tfitzgex
tom
Portland Oregon
I have asked the manager, The property owner 'wants to put in level 2 charging' but it would take a lot of electrical work, the buildings are 50 years old..
