tfitzgex
- tom
- Jul 26, 2021
- Portland Oregon
- 2021 Mustang Mach-E Premium extended range AWD
These are the notes, interesting that they redid 21p22
Also, my frunk button is missing
Ford Multi-Point Vehicle Inspection. Perform a thorough inspection of
fluids, wipers, battery, tires, brakes, safety systems, and
components.
99PX Ford Multi-Point Vehicle Inspection. Perform
a thorough inspection of fluids, wipers,
components.
1816 C 0.00 0.00
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE A: 0.00
B PERFORM RECALL 21G01
21G01E RECALL 21G01
1816 W (N/C)
1 NK4Z*10C666*B CONNECTOR (N/C)
CORE CHARGE W (N/C)
-1 NK4Z*10C666*B CORE RETURN (N/C)
MT21G01C MTIME
1816 W (N/C)
MT21G01B MTIME
1816 W (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE B: 0.00
18666 Customer requested 21G01 be performed to enable blue cruise.
Updated modules in order from the instruction sheet. made it to step 19
without issue. Found 21P22 has not been performed so I updated the
OBCC, DCME, DCMF, DCMG, DCMH, RFA, and BCM. The BCM Update Failed twice
without an error code before finally programming and removing itself
from the available updates list on FDRS. Proceeded to step 20, there
was no update from the GWM, moved on to step 21 to update the APIM.
Updated APIM, and now there is an update for GWM. Updated GWM and then
the APIM again before finally being able to finish the program. Test
drove and bluecruise worked correctly. Requesting additional time to
program modules additional times outside of the program so that I would
be able to finish the program in the correct order.
C** CUSTOMER REPORTS VEHICLE DIED WHILE DRIVING AND NOW NO CRANK NO
START
CAUSE: .
12651D BODY / CHASSIS / ELECTRICAL (BCE) - TEST
1816 W (N/C)
MT212245 MT212245
1816 W (N/C)
12651D54 JUNCTION BOX - HIGH VOLTAGE BATTERY
(BEC) - REPLACE (10C666) - L
1132 W (N/C)
MT MTIME
1132 W (N/C)
FC: PART#: COUNT:
CLAIM TYPE:
AUTH CODE:
1816
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE C: 0.00
18666 7.00
Customer towed in car that would not start. Was able to manually
pop the hood and get the doors open by jump starting the battery,
vehicle would still not start. Connected FDRS and pulled codes. Had
multiple codes that cleared. One stayed P1A10 Which had a TSB out for
it. .Performed PCM software update as per TSB 21-2245. Vehicle now
starts and runs as it should, all codes cleared. FSE instructed us not
to release the vehicle to the customer while we order a part under his
direction.
Replaced BEC (HV junction box) as per FSE. mtime needed for no
coolant bleeding labor op and for road test.
D** CUSTOMER REPORTS RIGHT SIDE STEERING WHEEL SWITCHES ARE
DELAMINATING
MT9C888 STEERING WHEEL SWITCHES
1816 W (N/C)
1 LJ8Z*9C888*C SWITCH ASY - CONTROL
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE D: 0.00
18666 customer states that the sterring wheel control switches are
delaminating. Removed and replaced both right and left hand switches
upon further inspection they were both delaminating. Mtime requested
due to lack of labor codes.
E** PERFORM PROGRAM 21P22
MT21P22B CUSTOMER STATES POWER TRAIN MAL
1816 W (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE E: 0.00
18666 Performed open program 21P22 in order to finish program
21P22. Updated OBCC, DCME, DCMF, DCMG, DCMH, ABS, RFA and BCM all
modules completed successfully in just over an hour with the OBCC
having a second update after finishing the list.
F** CUSTOMER REPORTS AIR BAG LIGHT IS ON WHILE DRIVING
01CFL RECOMMENDED MAINT
999 C 0.00 0.00
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE F: 0.00
G** Tire Rotation Service
CAUSE: Performed tire rotation
46CFL04 Tire Rotation Service
1667 C 0.00 0.00
SUBL RENTAL CAR PER FORD PO#125621
W (N/C)
PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE G: 0.00
18666 PERFORMED TIRE ROTATION, INSPECTED AIR PRESSURES.
H** RENTAL CAR PER FORD
RENTAL RENTAL
999 W (N/C)
components.
components.
1816 C 0.00 0.00
21G01E RECALL 21G01
1816 W (N/C)
CORE CHARGE W (N/C)
MT21G01C MTIME
1816 W (N/C)
MT21G01B MTIME
1816 W (N/C)
START
CAUSE: .
1816 W (N/C)
MT212245 MT212245
1816 W (N/C)
1132 W (N/C)
MT MTIME
1132 W (N/C)
FC: PART#: COUNT:
CLAIM TYPE:
AUTH CODE:
1816
18666 7.00
direction.
DELAMINATING
1816 W (N/C)
1816 W (N/C)
999 C 0.00 0.00
1667 C 0.00 0.00
W (N/C)
RENTAL RENTAL
999 W (N/C)
