Deleted member 19900
Guest
Delete
Because it’s a rigid structure that moves together!!The latch is in the middle, and you suggest pushing on the two sides. I can't make the physics of that work in my head.
He said, "DON'T" push on it. Anywhere!
Who said you need blunt force? You are merely pushing on it to close it. I’ve never heard of anyone damaging the outer hood panels while closing them.It would be kind of awkward having a power cylinder in the middle when trying to load something, wouldn't it?
I still don't agree with you. There's a difference between power cylinders slowly drawing something closed from the sides and blunt force trauma.
There is a drain hole at the bottom of the frunk that the air will escape when closing the hood.If you think about it, this is what probably makes the frunk difficult to close. It's basically a small plastic box with a seal around it. Where does the trapped air exit from when you close it quickly?
I have had the entire frunk bucket out several times working on the car. Closing the hood is no different if the bucket is in or out. My hood closes easily no matter what.Agreed, but is the hole big enough for that sudden amount of air? Compared to closing a standard trunk that's far larger and not similarly sealed because of the back seat etc., I would argue that's why it's so hard to close.
As of next month, I will have owned a Mach-E for 3 years. I am very familiar with the car inside and out having torn apart almost every inch of it. I store towels, cleaning supplies, the portable charger among other things in the frunk. At one time I installed a complete air suspension setup in there including the air compressors, tank and air management computer system. I use a foam canon and pressure washer to wash my cars and a high pressure air cannon blower to dry them. I have never found water in the bucket yet. Everything on the outside of that seal routinely gets dusty and I have to clean it after washing the car but nothing inside the bucket gets dusty or wet.Perhaps your isn't sealed anymore...
This is a great document. Most body structures are designed similar to ice. The one that stood out for me is the reinforced floor panels and the lower part of side panels to protect the battery. This is why the Mach-E performs so well in side crash testing.In case some did not click the link, there is some fun source data buried there:
Ford Mach-E - Steel.org
It seems like the drain holes in the bottom would let the air out as wellIf you think about it, this is what probably makes the frunk difficult to close. It's basically a small plastic box with a seal around it. Where does the trapped air exit from when you close it quickly?
I would've if I could've. The doc was published 4 months later.Some "sharpshooter" will come along and tell us we should have read it before buying the car.
This is on my list because of a coworker repeatedly saying ‘I just can’t believe they sent it out of the factory like that’and the lift gate on my current one.
