scoopman
- Jan 30, 2021
- Bay Area
- 2023 KIA EV6 GT, 2021 VW ID.4 Pro S
- former electric pony jockey
As many of you know, I just had my High Voltage Battery Junction Box replaced. It failed in some way, perhaps through electrical arcing, and was "stuck" closed, cutting off the HVB from the rest of the car. This was not a fun experience.
Since getting my car back, I've been very aware and thinking of whether I ever remove my L2 charger (as an example) while it is still delivering current -- and I have at times when my car was in the process of preconditioning and holding temperature for a departure time in the morning. I wonder whether removing the L2 charger while it is delivering energy may put undue or unplanned stress on the part that failed.
Unfortunately, Ford seems to be making it easy to have unplugging L2 while under load unavoidable:
This might be a design flaw Ford should consider fixing through software. They should consider changing charging behavior under L2 to be:
(There's a whole other discussion on why the BECM commands the HVBJB relays sound like they click on when I so much as breathe near my car in the garage. I wonder if this is putting unplanned stress on these parts that Ford may not have considered when it figured out the rating cycles for the parts).
- Departure times are the only way to precondition, and, when plugged in before the set time, the vehicle preconditions the HVB and the cabin drawing from the L2. This temperature is held for 15 minutes (I think) after the time set, and draws power from the grid during that whole time. It's difficult / impossible to precondition when desired without planning and pre-scheduling with the car, so it encourages setting precondition times that may not be desired on a particular morning.
- The L2 charge plug does not lock onto the car under load, and the user can remove it by using the physical latch on the plug. and just yanking it out while it is delivering 9+ amps. In other cars, such as our ID.4, the L2 charger is locked by the car and will not release if the system is actively accepting power. In that car, you must press the unlock button on the key FOB for it to stop charging and release. The lock UX is very consistent and you know it will unlock if you press it. As far as I understand, the Mach-E only locks on L3 charging, and does not lock when only L2 is actively delivering power.
- On my Mach-E, if it is actively preconditioning and holding temperature, pressing the "unlock" button in the middle of the LED status rings DOES NOT stop the preconditioning process and will continue to draw power. There appears to be no easy way to stop preconditioning and get in your car to go without pulling out your phone and encountering lots of app friction to turn off the charger.
- Charge port locks the L2 charger onto the car when it is actively accepting charge. User must press the "unlock" button next to the J1772 connector in the middle of the LED ring before the mechanism allows for the J1772 to release
- Pressing the "unlock" button should be a clear signal to the car to ALWAYS stop receiving energy (whether or not Ford has a mechanism to physically lock the connector) so that the L2 or L3 charger can be removed. Under no circumstances should the unlock button be essentially ignored as it appears it is during preconditioning currently
