Disable front camera washer?
NewGuy
NJ
Ready to order
Has anyone come up with a way to disable the front camera washer? I've never encountered a time when I want/need it, and I hate the blue/orange stains on the front bumper.
Thanks.
MacherAWD
North Shore MA
Healthcare Software
Thanks.
After 2.5 years of ownership I just put 2+2 together, that weird bird poop looking mark that always appears on my grille is from the camera washer....gotta remember to wipe that spot AFTER I use my washer fluid.
Deleted member 19354
Guest
Thanks.
Mine never came properly equipped with it. Unfortunately not a clue
AtomicInternet
SC
Focus RS, Mach E Premium
If your front camera washer is operational, you're in the minority. I'd even consider removing the module and selling it.
That said, I'm sure it's in the Forscan options.
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
I use cheap $$Store washer fluid, it's blue but I cut it 50/50 with water because it doesn't need to be that strong.
I don't see smurf poo on the front of my car after using.
dwst480
Dustin
Iowa
2023.5 Vapor Blue MME Premium RWD ER, 2021 Toyota RAV4
Dead serious here: There's a front camera washer?
Just went outside to check and I'll be damned...there's a front camera washer!
LinkRS
Rich
2023 Mustang Mach E GT Performance Edition
Yes, it was one of several things Ford deleted after MY22. If you have a MY23 or later, it will not have that component. You also don't have the kick-to-open feature on the tailgate :-(. If you have a MY22 or MY21, you *should* have the washer, time to take it to Ford LOL. Good luck!
dwst480
Dustin
Iowa
I've got a late '23 and knew about the kick-to-open (one of the few things the car doesn't have that I wish it did). I just checked and I see the door for the front washer, but I guess I don't know for certain there's a washer in there. From what you're saying, I guess maybe not. ?‍♂
I made it through winter in Iowa without missing it, so I guess I'm fine either way.
DevSecNetOps, General PITA
I don't think mine even works. I've never had the front of the car sprayed with anything
circatee
Georgia, USA
Mustang Mach-E GT PU, 2025
No, seriously, actually, very serious, there's a front camera washer?
I've had this car almost a year, and never knew that! I feel a little ashamed, to be honest...
If you have it it's a little back square next to the front camera in the grille.
IMDIDOC
Alex
Buffalo NY
2021 Mach-E FE
Optometrist
What makes me scratch my head is other car manufacturers have these features and they work great, but Ford takes them out because they are troublesome rather than reverse engineering the ones that work, changing the design slightly to avoid a lawsuit and make it work. I've had Audis and the trunk and headlight washers worked flawlessly.
