- Jun 24, 2020
- Vermont
- 2024 Kia EV9 GT-Line
Okay, so you don't actually want to disable the feature, you want to change the way that it works. I don't know of any modern cars that work that way.I just want it to behave like every vehicle made before the late 2000s when turn signal controls began to be intercepted by the BCM. If you hold the stalk up against the detent, the signal stays on for as long as you hold it. If you push the stalk past the detent, the signal stays on until you reset it or the wheel resets it after a turn. If the stalk is in the middle/off position, no signals are flashing, period.
