DIY solution to repair a ding?
mu5e
Seattle
None
I have a small ding at the back, how can I fix it? I ve heard I can order paint in matching color and do some patching.
Ford Mustang Mach-E DIY solution to repair a ding? 1000000130
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Order the paint directly from Ford. I tried off brand ones and the blue didn’t match 100%. Also didn’t have the flakes.
Then use a 1mm applicator to fill it in a little at a time until the new paint is just above the surface. Wait at least 30 minutes between each application. Longer the better.
Once it’s above the surface, rub it with a damp cloth to make it the same level as the original paint. The paint is water based, so will come off with not much effort.
mu5e
mu5e
Seattle
None
Thanks, how do I get paint from dealership? Their service department should have it?
That’s not a ding. It’s just a small paint chip. I got Grabber Blue and clear touch-up paint from Touchup Direct. Very good match and they have tutorials. ??
pepiopee
2023 Mach E GT
Reviving an old thread here a bit @AliRafiee but should I do this myself even if I have my vehicle on lease? Not sure what the rules are but I'd rather take care of it for cheaper myself unless I'm forced to do all work at the dealership per a lease.
Small chips are not a big deal according to what I've seen. To me personally, a small chip is a big enough deal so I like to touch them up. ??
I'd normally agree but these are deep and don't want the possibility of rust so I'd like to fix it to essentially seal it.
You will have to work very hard to get rust there. Most panels are aluminum or plastic.
Maui
Austin, TX
2024 Mach-E Premium
Software
BTW, ford parts has a similar part size and price but you can use points to redeem it :)
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
Hi Ali
I jump on this thread since I discovered a ding in my trunk panel caused by 1 of the women in my house.
It looks too small for PDR, but maybe I can do it following your steps above? I saw that I can order the paint from Ford.
Thank you
Ford Mustang Mach-E DIY solution to repair a ding? IMG20250713195901~2
AliRafiee
Ali
Seattle WA
Software Eng.
Hi Ali
Thank you
That looks like it’s at a curve and on a plastic part. And is there a chunk missing?
HughJazzol
Norman
Miami
Yes to both. I discovered it today as I washed and applied Turtle wax hybrid thing. I assume that being on the curve makes a repair harder.
EDIT - no, it's not a hole, so no chunk is missing. Simply the blue paint scrapped off against the garage door. ?
AliRafiee
Ali
Seattle WA
Software Eng.
At the curve it is a bit harder. Clean it up and give it a shot. You can’t make it any worse.
Just apply in small increments.
