Does my 12v battery charge if I fast charge
Lynn
Lynn
Olathe
2021 Mustang Mach-E California Route 1
Lab Technician
Hello everyone so I’m having an issue with receiving an OTA update, my car says the update was interrupted by another process. I’m under the impression that the 12v battery could be the culprit. I don’t have home charging currently so I’m using fast charging. My question is does the 12v battery charge if you fast charge the vehicle ? I would I need a slower charge ? Also I’m not sure if there is away to check the charge of the 12v battery without a multimeter? Any help is appreciated greatly.
Thank you
Lynn
There is no way to check the 12v battery status, no.
Driving the vehicle charges it. Yes, it charges while charging, but in 30 minutes that's almost nothing.
If driving it doesn't do it, put a battery charger on the jump posts.
Lynn
Lynn
Lynn
Olathe
Lab Technician
Ok thanks
bbulkow
menlo park, california
Honda CRV
Thank you
Lynn
Alternately, since you have a 21, if you are on your first battery, this could be a sign that your 12v is nearing end of life and due for replacement.
  • Like
Reactions: TWD
Thank you
Lynn
Just follow this: Thread 'How To Get Failed OTAs To Install'
Schedule the update to automatically install at 1 AM when you aren't using the car (and let it do it that way rather than manually), that will help in some cases as well.
wchristie
Guest
Thank you
Lynn
You can either have your dealer scan for 12V battery health, or purchase and OBD-II scan tool (like Veepeak ODBCheck BLE) and download the Car Scanner phone app. Connect the app to the scanner via bluetooth. This gives you access to all kinds of data including the 12V battery.
Lynn
Lynn
Lynn
Olathe
Lab Technician
Thanks everyone , i tried just about everything I could even calling the over the air team and everyone told me my 12v looked fine. I finally just took it to my local Ford and they updated everything for me. So I’m good for now.
