Logal727
C
The series of updates for Bluecruise changed how far I have to pull the inside lever back on my car, takes much less effort now, it was very noticeable
Terik2005
Terik
New jersey
2021 Ford Mustang Mach-e California Route 1
Train Engineer
Since the interior door release lever no longer activates the presenter, it won’t wear the presenter every time the door is opened from the inside. ??
Now I just need to scrape the kibble together in order to get a Mongoose Plus. ??
Mongoose plus?
Terik2005
Terik
New jersey
Train Engineer
It’s the cable most are using to interface their FDRS rigs with their cars. It’s a wee bit pricey. ??
Ohhh. Does it only help u update at home before official releases?
FDRS is the software that the dealers use to diagnose and update the cars. Ford doesn’t make the software updates available through it unless they are official releases. The availability of those bits of software is usually earlier through FDRS than OTA, sometimes several months earlier. ??
More info here: https://www.macheforum.com/site/thr...ach-e-with-fdrs-alternative-to-forscan.10217/
i8iridium
Pat
Fort Washington, MD
2022 Mustang Mach E GT
U.S. Air Force (ret.)
Oh, I have no hurt feelings. Even if I did what does it matter? I was truly asking cause I cared. Just seemed like you really went out of your way to get that out there.
Dadams
Darrin
Grand Rapids, MI
22 Mach E GT-SOLD, 22 Sorento PHEV, 23 MachE GT RR
Maybe I just didn't notice, but I do not think my 2021 job 2 MME has ever used the door presenters when opening from the inside of the car.
I just checked my 22 GT May build date and I can hear the presenters working when using the interior door handle.
Gullwingdmc
Chip
Boston, MA
Weird, I just checked my 2021 Job 1 and the presenters don’t activate when opening the doors from the inside, they never have. When you pull the e-release the latch pops open which does push the door a little, but it’s not the presenter. I even tried in the back seat which only has the e-release and it did the same thing.
I did have the doors updates as part of the 21P22 CSP, but that didn’t change the opening behavior.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Any idea if this will be an OTA update, at some point in time? Bill
The 3.x.x update series has a ton of module updates with it. I suspect you'll be seeing all them come out over the next few months. GWM, then APIM and possibly a TCU, followed by all the rest of the modules. This is why they all showed up in FDRS at the same time.
Santiaventura
Santi
Valladolid - Spain
Mach e RWD SR TECNOLOGY+ & WHITE STAR
My 2021 (Spain) never activated the presenters too when opening from the inside.
