LaFong
- Nov 1, 2022
- Colorado
- Mustang Mach-E GT 2023 Vapor Blue Metallic
- Systems Engineer
OK, I have AM radio working on my ‘23 GT. I had tried earlier but one of the changes is in the ACM module, which was not in the spreadsheet at the time.
- Enable AM Tuner in ACM, by changing this setting from 1->0. My version of Forscan only has the As-Built module version, so I had to make the change manually.
- Set the AM Tuner as Available in APIM. You can use the Forscan APIM module, or change it manually (A->2) using the APIM As-Built module.
- I also enabled HDRSL, HD Radio Station Logos, in APIM. (1->5 if done manually). Not sure if that made anything different.
- You have to go into settings on the AM screen to enable AM HD. I only got one station to display the HD icon. The icon seemed to not be a button, like it is for FM HD, and the station sounded no different. Maybe I'm missing a setting somewhere, or AM HD is just too uncommon. Perhaps '21-'22 owners can confirm.
