markboris
- Mark
- Nov 13, 2019
- Sonora, CA
- Currently: '20 Shelby GT500 FPB '24 Mach-E GTP GGM
- Retired
I really like Jonathan's review's on Tyre Reviews. I trust everything he says and does because I believe he really knows tires.Use tyre reviews on YouTube to get the best explanations and objective rankings for tires.
For the last couple of years in his Ultra High Performance Winter tire test (not to be confused with his Winter tire test), the Michelin Pilot Alpin 5 tires have come out on top. There are two different catagories of winter tires, the hard core Winter tires and UHP winter tires. UHP winter tires are a little less aggressive in the snow (not as good as Winter tires) but they are better usually better in the wet and much better dry handling, noise and comfort.
I purchased a set of the Michelin Pilot Alpin 5 tires last winter and used them with great success. Like most other winter tires, you barely knew you were driving in the snow. As far as dry performance, I was amazed how well they did compared to my summer Pilot Sport S5's. Now, these UHP winter tires are no summer tire but they handled much better than I had expected. Steering was much more vague and they were more noisy than my summer's.
A month ago when I put my winter wheel/tire setup on, I noticed starting around 60 mph, a slight droning noise which increased as I drove faster and stabilized at around 75. It would come and go depending on the road surface. I absolutely do not remember this when I had them on my car before and thought it was very strange. I had the tires checked for proper balance and they did not need any rebalancing. To check that I was no imagining this, I remounted my summer wheel/tire setup and no drone whatsoever.
I thought I could maybe live with the slight drone but one trip back and forth to the airport (2 hours each way) I realized I couldn't. Maybe it's just these tires on this particular car that is causing the noise, but I don't know. In any case, I just purchased the previous UHP winter tires that Jonathan had recommended as number one which were also Michelin's previous tire to the tires I am running now. They are the Pilot Alpin PA4 NO (Porsche spec tire) and there is no drone. Not only that but the tires are overall quieter than the Alpin 5's but what really stood out was the steering response. It is very responsive which is what I like and might even be more so than my summers. They handle great in the dry (for a winter tire) and are a bit more firm than the Alpin 5's. Now all I have to do is test them out in the snow which won't be too long since it's been dumping the last couple of days up at the ski resort 45 min away. ?
Alpin 5's after one winter's use:
Aplin 4PA NO before mounting on wheels.
