Florida Man experiences first LVB issue (I think)
breeves002
St. Louis, MO
2021 Mach-E GT PE
It is possible it was a low LVB but not necessarily the case. It could have been a network glitch with some module not waking up right. I've seen it in every Ford I've owned. The chimes through the IPC just means the IPC didn't connect to the ACM immediately upon boot so it defaults to its speaker. It has happened at least once in every modern Ford I have owned.
Logal727
Logal727
C
Ah ok, good to know, thanks for *chiming* in! (I'll see myself out.)
Logal727
Logal727
C
Ok, well, happened again this morning (didn’t plug in last night) and as soon as I opened the door, the Sync Screen said “Shutting Down to Save Power, start or turn off vehicle” Chimes came through IPC again.
So I turned it on and hooked up my OBD2 reader, LVB SoC was mid 40s, voltage was 14.7 or so, and LVB SoC was going up. Attaching screenshot I took when LVB hit 60s in like 5 minutes. Should I be worried?
I feel like since my living room and office area is right next to my garage my PAAK is constantly connected, so maybe that’s an issue? Overall it seems like LVB is recovering, just need some advice or someone to make me feel like not freaking out haha.
Ford Mustang Mach-E Florida Man experiences first LVB issue (I think) 1AB6D3F0-E7C6-4502-80D5-6163905087E3
That looks normal to me.
DevSecOps
Todd
CISO
I don't think it's the LVB at all. 14.4 is not the LVB while idle either however that's the HVB topping it off. So your HVB, the BECM are doing their job.
I think you have something else going on.
RonTCat
Ron
Mach-E wannabuy
Keep an eye out for an OTA update completion. You may be in "inhibit" right now.
Logal727
Logal727
C
Thanks for looking! Was back to normal after a drive, not sure what it is. I also forgot that the headlight bug came up right away when I opened the door, it kept dinging at me so I turned the dial back to Auto and then the sync screen gave me the message about saving battery. Weird stuff.
Logal727
Logal727
C
Hmm my OTA API status hasn’t changed on the site, but will keep an eye on it
Logal727
Logal727
C
So came out to car this morning and the sync screen was on inside an all the mirrors were open. Sync screen said “Shutting down to save power”, so it looks like as others have reported on here the sync screen is coming on on its own? I am usually pretty close to the car with PAAK, it’s only one wall from the garage to my living room couch, but haven’t had this issue at all in the 6 months I’ve had it. Weird stuff. Maybe I’ll just keep it plugged in all the time.
