Ford Connected Charge Station issue
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
So the electrician says I have a 50 amp breaker. Should the setting on my phone be less than 48a?
Yes! The issue is your settings for sure. Do not use it until reset Properly. You can only charge with 40 amps on a 50 amp breaker, safety. If you have 48 amps as a setting, that may be your problem and it is unsafe.
I made the same mistake with the incorrect circuit board labeling and mine did the same thing. You can remove the cover with the breaker OFF and confirm the settings, they should be the 40A 50A CB settings. Remember that the red block is correct, not the circuit board markings. Ford mucked this one up.
I pulled 48 amps through a 30 amp breaker and 30 amp sub panel breaker and it did not pop, but the charger erred out. That’s when I learned from this site that the circuit board is wrongly labeled at the charger.
Ford Mustang Mach-E Ford Connected Charge Station issue 189E0981-392F-4F4C-B82F-2D81AF880482
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
I may have misread the manual but it was my understanding that any invalid dip settings default the max current to 48amps.
Correct. But they must be invalid and do default to 48 A
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
You can try adjusting your phone to 40 Amps and try again and see if it works. I suggest waiting until the DIP switches are confirmed. “On” on the Red Block is ON (or “1” in the manual)……NOT what the green board says, but confirm for yourself And with Ford. As shown in this photo would be a 48 A 60A CB setting.
I cannot believe Ford has not put a manual addendum out yet.
Ford Mustang Mach-E Ford Connected Charge Station issue 1645187037466
Ford Motor Company
Official Ford Account
I had a Ford connected charge station installed Saturday but it will not charge. When plugged in to the car the charger indicates that is charging by the pulsating blue light. But in a few seconds it goes to a solid blue line that indicates it's in standby mode. And my Ford pass app says plugged in but not charging. My app is set to charge when plugged in. I contacted ford customer service and all the technician could say was "Hmmm, that's odd. Either you have a loose connection or a bad charger." Any ideas?
Hi there! Will you send us a private message with your VIN and dealership info? I can look into things on my end. Thank you!
JeanneB
Jeanne
Plainfield,Il
2023 Ford MME GT
finance manager
Ford Mustang Mach-E Ford Connected Charge Station issue 1C1D7528-AC1E-42E6-A22D-2AA310D77235
Ford Mustang Mach-E Ford Connected Charge Station issue 2F3BBF77-D4FF-47BA-BCFC-28170CC56196
My charger came with these settings so I don’t know which one to use. Every one I look at is different. Should it be On On On 1 1?
JeanneB
Jeanne
Plainfield,Il
2023 Ford MME GT
finance manager
Ford Mustang Mach-E Ford Connected Charge Station issue 7A056394-5338-4132-A447-498774E2ED5C
Ford Mustang Mach-E Ford Connected Charge Station issue 26FE3C8D-F3E3-4570-BB26-3C2EF6C14654
Yes, On-On-On is the 40A setting for a 50A circuit.
When I installed mine, it came from the factory with all switches off = 48A.
JeanneB
Jeanne
Plainfield,Il
2023 Ford MME GT
finance manager
I can't figure out how to send a pm but I just need to know what the dip switch setting should be for a 50amp circuit breaker. Should it be On On On Off Off? I see so many conflicting options and my slectrician is coming in the morning.
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
From Manual 1 of your post: 0 on on on for 40 amps.
From Manual 2 of your post: on on on off off
From my manual above: 0 on on on for 40 amps.
I do not know what to tell you. This is baad.
JeanneB
Jeanne
Plainfield,Il
2023 Ford MME GT
finance manager
Thank you!
JeanneB
Jeanne
Plainfield,Il
2023 Ford MME GT
finance manager
From Manual 2 of your post: on on on ??
I know! I'm so confused!
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
Please do and If there is a revised settings manual, I did not get one with My Connected charge station. I would love to know the proper settings for 24A. Maybe that’s why mine errors out some time times.
BTW mine was November 21 delivery. IT DID NOT COME with this addendum. Ford needs to make sure every User gets this manual addendum.
skiingj
Roseville, California
Mach-E Premium
Very confusing. I took my cover off to see how I'm setup. I have a 60A circuit. I was present when the unit was installed. We did not change any dip switch settings. Looks like mine are all set to off. I have not really had any issues charging. It appears there are numerous dip settings to accomplish 48A charging. Now what's the difference. ?‍♂
Ford Mustang Mach-E Ford Connected Charge Station issue 20220218_104357
hawkeye3point1
NH
The bottom 2 switches (#s 4, 5) should be OFF, ie. to the left, all others (#s 1 - 3) should be ON, ie. to the right, for the 50 amp circuit you have.
Mine is one of the newer builds with the gray dip switch block, it came with all switches ON.
Thank the manufacturer, Webasto for the confusion here, their logic markings are reversed, the way it is marked, 1 = off, 0 = on. This is all hashed out in the Sticky Thread, btw.
Edited from original due to communication failures.
